Date: 08/13/2021 10:39 am
Date: 05/19/2018 04:56 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 05/15/2022 11:36 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 04/30/2023 04:31 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 11/29/2018 10:26 am
Date: 07/08/2022 11:51 pm
  • Online today: 128
  • Guests: 83
  • Total: 83
8 inch ford spline numbers
Started by stever, February 09, 2008, 09:24:30 AM
9" Center section has either 1 or 2 vertical ribs and 8" center section has either 0 or 3 vertical ribs.  (this is for FORD parts, some aftermarket companies may make them differently.)
Thanx Guys...That is just what I needed. I am going to the garage now to get busy.
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Quote from: High_Horse on February 09, 2008, 09:13:52 PM
...Are the 8" and 9" that close in looks? They appear to be identical to me at a glance.
The easiest way to tell them appart at a glance (for me), is that with an 8", you can put a deep socket with a 6" extention on ALL the mount nuts. With the 9", you can't due to a buldge below the pinion.
While we are on this subject...I currantly am changing my carrier from the single trak to the limited slip Ford I got from lil haus. While I was at a swap meet last weekend I came across a cone on a table that was clear to me to be the same size as my cone but it was marked 9". It was the borg-warner cone. Also... a guy came over last nite and noticed my work bench and said ohhhhhh...9" inch. Are the 8" and 9" that close in looks? They appear to be identical to me at a glance.
I agree with Bill..
28 Teeth-spline
Quote from: stever on February 09, 2008, 09:24:30 AM
The rear i have is from a77 v8 mustang is this a 28 spline rear?
Yes.
BTW: All 8" carriers are interchangeable.
stever
yes i am from whiteland indiana,and no i dont know the gliddens.
