Date: 04/30/2023 04:31 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 10/03/2018 02:00 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 12/09/2016 08:34 am
Date: 07/30/2018 04:32 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
  • Online today: 802
  • Guests: 390
  • Total: 390
lowered 79-80
Started by bobscat, January 30, 2008, 10:20:39 AM
I am looking to convert my 75 to coil over shock in the front end.  Speedway has a good kit.  Anybody have any experience???
Why am I doing this.  I want to control how much I will lower the front of the car.  Ride height is adjustable.  Also if I need more spring it is an easy swap.
I cut a coil off mine and I do not think it affected the ride much.  However it has been about 13 years since I lowered my wagon so I am used to it by now ;D
bobscat
Cool, those are some nice lookin rides you guys posted.  Thanks for the input to everyone!  For you guys that have cut the coils, how much did this affect the ride? I have done this on other vehicles, with some not so great results, just wondering.  I don't expect it to ride perfect, but on the other hand, I don't want a log wagon.  (The better half may end up driving this one)
earthquake
Heres a pic of my 80.It was the best I could find at this time.I do have some that really show how low it is,I'll keep looking.
   Doc.
earthquake
Quote from: Pintony on February 02, 2008, 12:40:08 PM
Maybe you need a set of koni's set up on firm??
Koni doesen't make a shock that firm.I have about 2 in between the frame and axle and they are no help unless the shocks shave the top of the speed bumps off.
Half a coil cut off in front, and 1" Walsh lowering blocks will both look good and ride ok. I've done 1/2 doz that way with no problems.
SWEET.... (to be done in the voice of Eric Cartman)
This is the only picture I have of my 79 wagon loaded on this computer.  Sorry it is not a very good picture.  1 coil is cut off the front springs and I have Racer Walsh blocks on the back.  It is about as low as I want to go as it is already a pain to jack up.  I have to drive up on blocks to get my jack under the front cross member
Quote from: earthquake on February 02, 2008, 12:38:06 PM
I lowered my 80 wagon 2.5 in front and 2 in the rear.with 2 in lowering blocks in the rear the axle hit the frame on a good bump,and speed bumps are my worst enemy.it does look good and the car handled like it was on rails but the bottom was taking such a beating that we are putting it back up.I'll try to find a photo to post.
earthquake
Pinto1600
Bobscat,
         Try baggin' it. There are kits out that are made for the Mustang II. Thew hot rod guys use that front end all the time. As for the rear end,that could be fabbed' up. Good luck!
Racer Walsh still carries lowering blocks as of 5 months ago when my son bought some 1 1/2 inchers  ($50) . They are too wide for the isolator bracket (74+) without modification. They are also surprisingly heavy solid alloy. I plan on making them swiss cheese with a drill press and adding a 1/2 inch correction wedge to keep the diff aligned.
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
bobscat
Does anyone have a picture of a 79-80 body style that is lowered?  I am thinking of dropping my 4cyl car, and would like to see how far to go to make it look right.  Also, does racer walsh still supply lowering blocks?
