pinto for sale
Date: 09/11/2016 09:47 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Date: 02/21/2017 06:29 am
Date: 07/04/2017 03:26 pm
Date: 09/22/2020 11:33 pm
Date: 07/13/2018 02:21 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Bell housing
Date: 08/23/2017 05:41 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Online today: 776
  • Guests: 711
  • Total: 711
swaping a late 2.3 in an early car
Started by volksnut, January 19, 2008, 12:36:49 PM
volksnut
on the fuel pump hole, nope...the casting is there with bolt holes but it's cast solid ...on the flywheel, there's one on the motor but I don't know if it's correct, it did have a clutch set up but the disc has different splines than the early model, so that I do know will have to be changed...I tried cross referencing the clutch set up and starter and all was different...is the ring gear different on the late model? Anyone know... But like you said maybe use all the early stuff from flywheel out?
I thought the later 2.3s just used a block off plate where the fuel pump goes. Did the block not have that? Just a thought for that. As to your other question, I'm not too sure, but I'd think you'd run the early model clutch & flywheel. With the starter you'll probably want to run the earlier model as well just to make sure it bolts up to the II bellhousing you got.
volksnut
long story short, daughter has blown her 74 Mustang II motor(v6) so I bought a 2.3 to swap, turns out it's a later n/a 2.3 (87 Mustang to be exact) so I got the correct II bellhousing,oil pan, pick up,mounts,water pump, pulleys,distributor,bla bla bla....now the motor had already been changed over to carb...I'll have to run an electric fuel pump also.....now when it comes to flywheel, clutch, starter....do I run the early or late stuff????
