Date: 11/23/2017 05:44 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 01/28/2017 12:30 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 776
  • Guests: 682
  • Total: 682
Pinto 4 lug rotor to 5 Lug??
Started by neil m, January 18, 2008, 07:14:31 AM
Then I would do the 5 lug swap...I thin the two rotors are 90$ plus shipping
Comes in a Small Chevy and a Small Ford Pattern 5 lug...
FrankBoss
neil m
Hi Frank my pinto is a 1978 hb, thanks for all the info guys
loving anything with the blue oval
yes the early Pinto Requires a Mod to the stock bracket...
I've been driving my 72 for a while with the MustangII rotors from Speedway...
FrankBoss
Quote from: turbo toy on January 18, 2008, 07:26:01 AM
This is the cheapest and easiest way to go on the rotors.
http://www.speedwaymotors.com/p/1964,354_5-Bolt-Mustang-II-Rotors.html
A note here. This application will only work on 74 and up cars. The early spindles are different and will require a different caliper bracket.
turbo toy
Quote from: Pintaro on January 18, 2008, 07:39:42 AM
Your Granada rear will fit perfect.width is the same,spring perches are the same,the driveshaft will even work without modification.You will have to find a longer shock,about 3 inchs longer.that is if you use all the hardware from the granada.thats U-bolts and shock plates.Now for the front.If you have the granada rotors and calipers,they are 11 inch.you can get a kit to move the calipers out to accomidate the bigger rotors.If you dont have them,you can buy 5 lug 9 inch rotors that just replace the 4 lug ones.All the parts you need can be found on the wonderful world of E-BAY.This setup is what I have on my Pintaro,Although the gear ratio in the granada rear is way high for a 4 banger.
        hope this helps,Mike
Actually, the Granada rear is 1/2" wider than the Pinto and the mounting pads are also 1/2" wider from center to center than the Pinto. You can push the springs over 1/4 inch on each side and make them work, but it isn't advisable. Also you need to use all the Pinto plates because the Granada plates don't have the shock mounts in the right place.
I have 5 lugged both Early and late Pintos...the real advantage is wheel selection.
I have done GM calipars ,grandada, maverick and aftermarket...
if you use the the rotors from speed way it will be the cheapest.. I bought a pair of rotors from them for the cost of ONE stock replacement rotor from AutoZone or Oriely's . Have you priced a early pinto rotor lately?
As for better stopping power notice the larger brakes being better unless you have power brakes..and the lager parts weight quiet a dit more than the stock 9 inch rotors.
what year is your Pinto?
FrankBoss
PS: dont forget to put your location on the PCCA Member Map, someone might have better resources in you area.
Pintaro
Quote from: neil m on January 18, 2008, 07:14:31 AM
Hi all im wondering about changing my front rotors from four lug to five, can anyone tell me if i can use a Mustang II rotor, and if it will fit right on. i have a 8" rear from a granada, Im wondering is it worth making this change?  if i dont make this change where can i get the four lug hub/rotor? any pros and cons will help me in my decision. Thanks Neil
All Mustang II's came from the factory with the same 4 lug pattern as Pintos.
WHY do you want to change to 5 lug?
If you want to use 5 lug 9" rotors, be sure the rear drums the new axle are the same size as the Pinto ones. If not (most likely), you could have issues.
BTW: Be sure you have wheels BEFORE you convert to Maverick/Granada axle/rotors. They take the 2.75" center holes and they can be hard to find.
neil m
