turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 04/15/2017 05:14 pm
Date: 11/08/2019 10:01 am
Date: 08/30/2018 12:59 am
Date: 02/14/2019 06:27 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
  • Online today: 344
  • Guests: 178
  • Total: 178
ENTRY WINNERS!! - 2009 Calendars WE NEED YOUR SHOTS.
Started by Scott Hamilton, January 09, 2008, 09:20:19 PM
Charter Member's Choice
CookieBoy- 73 Runabout
Jugalo777- 78 Hatchback
77TurboPinto- Connie's Car
Phils Toys- 76 Bobcat
Redmustangman3- 71 V8 Pinto
77TurboPinto- Bill's Car
BobScat- V8 Bobcat
RKK- 76 Runabout
71PintoRacer- 71 Sedan "Spearco Special"
Pintony- 71 Stdan- Mustard
Pintony- 72 Runabout- Green
Noforkin- 71 V8 Drag Racer
TruboPinto72- Black Pangra
Pintony- 72 Red Wagon
Dan- 71 460 Pro Street
R4Pinto- 77 Sedan
PintoZeal76- 75 Sedan
Tigger- 79 Wagon
Beegle55- 78 302
CooieBoy- 78 Hatchback
Original74- Jade w/429 Miles
JimSkatr103- 72 Hatchback
PintoPower- 74 Pangra Wagon
PintoPower- 78 HatchBack
Pangra part 2
Final Fifteen! The month of JUNE
PHOTOS ARE IN!!!
The Pangra
NoForKin
Final Fifteen! The month of MAY
YES!! PHOTOS ARE IN !!!
ok here is my 71
  302 dart block 4 1/8 bore stroked to 364 ci  550 hp
  tunnel ram with 2 holley 450 carbs
  power glide trans  with trans brake
  6000 stall speed converter
  turbo action shifter
  ford 9 in. rear end
  456 gears with spool
  msd 7al3 Ignition  with pro billit distributer
  world heads
  painless 8 switch fused panel
  mega 200 delay box
  all fiberglass front end /hairy glass hood and trunk lid
  lexan windows
   32X14x15 rear slicks
  best  time 10.35@130.50 mph. 1/4 mile
   has gone 6.56@103.27 in the 1/8 mile
   PCCA  2007 Carlisle Best of Show and Best Modified
   2007 Ford Nationals ,Carlisle ,Best Modified
Final Fifteen! The month of APRIL
PHOTOS IN !!! :hypno:
OK I will add mine, 71 trunk car, modified 2.0 with headers, intake, Holley 390, crane cam, Mallory ignition, NOS plate system. Second owner, I've owned it for 15 years.
Final Fifteen! RUNNER UP...
PHOTOS ARE IN..THANKS BILL
Now for the 'His' Pinto.....
I bought this one in the fall of 2000. A coworker that knew I was looking to build another circle track Pinto told me about this one he saw at a gas station/garage. It belonged to the owners mother and was her daily driver until late summer that year. It had 32K, a 2.3/C3/6.75", and was tan with cloth chamois's interior. When I saw it I had doubts about it going to the track as it was in very good shape (less the right door and interior). She fired right up and drove onto my trailer. Connie and I decided very quickly to register it, at least for a while. All it took was one cruise night and we were hooked. The decision was made to keep it on the road and put a V8 in it, but my attention soon turned to an EFI 2.3T. The car is now yellow with black interior.
In addition to the EFI 2.3T, I also installed/swapped:
T-5 5spd,
AeroStar aluminum driveshaft,
8" rear from a Maverick,
Granada rotors,
FMIC,
Crusin' Wagon front spoiler,
all glass hatch,
79/80 Pinto rear spoiler,
Mustang/Cobra II front & rear sway bars,
factory Pinto tach. & gauges,
1973 Mustang wheels,
and Ford 'Zinc Yellow' color code 'B7'
Thanks for looking,
redmustangman3
Final Fifteen! The month of MARCH
PHOTOS ARE IN YIPPY!!!
Up for consideration is my 1971 V8 Pinto. This winters projects have been: (1) new intake scoop which required a stock hood replacement; (2) front and rear bumpers were replaced with rechromed pieces; (3) new valve covers and some hoses replaced under hood; (4) special designed Pinto logos on front fenders; and (5) timing gears (loud) installed. I really like the NEW LOOK and look forward to bringing the car to Knott's again this year. Joe In Morgan Hill, CA.
1971- 289 V8; B&M C4; 9" with 4:11 posi. Several suspension upgrades and body modifications.
1974- 2.3L wagon,4-spd,totally stock. Medium lime yellow, avacado interior, 99k miles.
1972- 1984 Mustang SVO turbo; 5-speed tremec; 9" rear w/positraction; fiberglass front & doors; upgraded suspension.
PHOTOS IN LOOKING GOOD
1976 Bobcat Woody  Wagon,
90,000 miles give or take a few 2.3l , ac, ps, no radio.
purchased on eBay  Aug 22, 2005 for $1976.  Upgraded the rims to the factory white wheels 2006 after getting a flat on the way to Carlisle. The car came  from Florida.  Original paint and woody siding. Placed a  dash cap on this past summer.Pcca #341
Final Fifteen! The month of FEBRUARY
PHOTOS are IN Thanks !!!
These are of Connie's car.
This car found us about 3 years ago. It was rescued by a guy that worked at the junk yard it had been hauled to. He purchased it before the title was turned in, and he made an attempt at putting it on the road and had plans to restore it. He did not have the Pinto 'know-how' to do much with it, and he did might have done more harm to it than good. He had contacted a good friend of mine asking if he knew of anyone that might want a Pinto and my name came up (some how). It took over three months for the owner to contact me, but he did and we went to look at with the intention of getting another parts car. The car ran, but mechanically that's all we could tell. During his ownership of it, he seller had lost the keys, busted out a quarter window, 'popped' the column, as well as dented it up quite a bit. It had an interesting interior and a few neat options that made Connie fall for it right away. Aside from the window and column, to put it on the road it needed: carb. work, a rear main seal, a steering rack, outer tie-rod ends, brakes and lines, a rear axle, rear springs, a battery, tires, a power steering pump, a radiator, an exhaust system, and a bunch of other things. Once we had it running well, we started in on the 'looks'. A plethora of NOS parts plus a paint job and here it is.
Thanks,
Final Fifteen! The month of JANUARY
PHOTOS ARE IN Looking Good As Always
Here's Mine,
1973 Pinto Runabout with Hot Pants Body Kit. 2.0L, 4spd, Full Restoration Inside and Out. Purchased 7/23/2006, Restore Started 11/26/2006  and 1st car show after restoration 6/3/2007. Modifications include rebuilt block bored .20, hardened valve seats for unleaded gas, header, Pertronix electronic conversion. Pinto seats with custom upholstery, interior restored top to bottom, Sony Xplod Stereo and Speakers. Rear spoiler is on it's way and hope to have installed by final picture time to complete the Hot Pants Kit. PCCA sticker already displayed.
for more pics see here --> http://www.cookieboystoys.com/73%20pinto.htm
Thanks for you consideration,
Cookieboy  ;D
Scott Hamilton
WE have the winners of the FordPinto.com 2009 Calendars,  Check it out!
If you are a winner you have until August 31st to  get your pictures to us...  That's right AUGUST 31ST!!
Download your instructions now and get cooking,
Click Here
http://www.fordpinto.com/2009PCCACalendar.pdf
The 2009 PCCA / FordPinto.com Calendar starts NOW,
Here is how it's going to work,
Now until April 15th 2008 we will be asking for you to 'enter' your Pintos by posting a picture of your Pinto & a short description in this thread. FYI- Every Pinto MUST have a PCCA Sticker BEFORE the final shoot.
April 16th- April 30th we will put up a poll asking for everyone to 'vote' on which 20 cars are the best.
May 1st-May 15th the Charter Members will cut the number of Pintos to 15 and decide what cars will be what months (with 3 as runner-up backup entries)
The Admins will announce the 15 winners on July 16th in this thread. All 15 winners will be expected to download the instructions which includes purchasing a disposable 35mm camera and shooting your car in a scenic vista of your choice. certain shots will be required, ie. front back side etc but you can 'ad lib' from there. Sorry NO DIGITAL images will be accepted this year due to misunderstandings about resolution as opposed to actual photo or file size. The only way to guarantee the SAME quality across the calendar is if everyone is on the same page.
The Charter Members & Admins will complete the calendars and have them available to order no later than September 30th 2008 through Cafe Press.
So... Let's start posting your Pinto Pictures & get the ball rolling!!!
No representation is made that the Charter Members or Admins actually know what they are doing, in each and every case of actual knowledge exhibited by any of your CM or Admins there has always been a definite deliberate admission of for thought that closely resembles IQ scores closer to mice as opposed to Horses (Pintos). Actual embellishments or expressions of understanding are limited in scope to curtail any real or known importance. User be worried.
The Shiny Police
