Bell housing
Date: 08/23/2017 05:41 am
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 10/24/2019 01:43 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 08/13/2021 10:39 am
Date: 09/09/2018 03:22 pm
Date: 01/19/2020 09:06 am
Date: 01/30/2017 01:48 pm
  • Online today: 656
  • Guests: 559
  • Total: 559
73 2.0 timing belt
Started by ponyboy, June 11, 2004, 09:37:55 PM
earthquake
Sorry Pintony but that what it said when I looked at it this morning,before you corrected it.Any one can have a brain fart from time to time no big deal.
Quote from: earthquake on November 22, 2007, 12:26:23 PM
Hey Pintony
    Ain't that supposed to be 1342.
That is what I put in the post.
GO find your glasses :o
earthquake
Hey Pintony
Quote from: mikes73pinto on November 21, 2007, 08:10:18 PM
ok on my 73 2.0 pinto were should the distributor be set when im at top dead center ?should it be turned all the way towards front of motor or about half way towards back please help cant figure this one out   thanks mikes73 pinto 2.0
Hello Mike,
The position of the rotor on the Dist is totally un-important.
Unless you are ANAL about how your spark plug wires are run.
Just set the cam and crank and tighten the idler pully and recheck that notheing has moved.
Now pop the dist cap and put #1 spark plug wire closest to the where the rotor is pointing. Move the rest of the wires to a 1342 firing order loosen the dist clamp, adjust Dist housing start engine and set initial timming with timing light.
2.0 Crank pully timing marks.
2.0 Cam Timing pointer
This might help.
My 2.0 on engine stand.
mikes73pinto
Poison Pinto
Well, that's what I get for looking at a manual.  :-[
Okay, on my 2.3 I4 that came out of a '74 wagon, the timing marks read as such from left to right:
ATC 10, TDC, BTC 10, BTC 20, BTC 30 with subdividing hash marks. This is reverse what my Ford manual tells me is "typical" and what I posted earlier.
I looked at my 302 V8 as well, and it was also marked ATC 10, TDC, BTC 10, BTC 20, BTC 30.
While these aren't 2.0s, I would say that TDC on yours is probably the 2nd, maybe the 3rd hash from the *left*.
As I stated earlier, many people advance their timing anyway, so setting it at the 2nd hash from the left should work either way.
Poison Pinto
The 7 marks on the damper pulley represent Top Dead Center (TDC), Behind Top Dead Center (BTDC), and Advanced Top Dead Center (ATDC). TDC is probably *not* the middle notch. As you face the engine, the TDC notch is most likely the 3rd from the right (5th from the left). On dampers with 11 notches, TDC is the 4th from the right. Many people like to advance their timing a bit anyway.
It's dark here, otherwise I'd go look at my 2.3 and see how the timing is set. If no one gives you a definitive answer by tomorrow, I'll post back.
ponyboy
I have a 73 pinto wagon that I just recently purchased. The body and interior are in great shape, but the engine ran poorly when I bought it. Shortly thereafter, the timing belt broke. I bought a new one, but I don't know how to line up the timing marks. I found a small dimple at the 6 o'clock position, behind the cam pulley, and a notch in the distributor housing, which I assume are timing marks. However, there are 7 marks on the crankshaft pulley, and none of them are marked. Which one do I use? I would appreciate any help with this problem, so I can get my Pinto back on the road. Thank you.
