Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 03/14/2020 01:52 pm
Date: 09/15/2019 12:38 pm
77 pinto
Date: 08/22/2017 06:31 pm
Date: 06/07/2018 01:45 am
Pinto drive train
Date: 06/29/2018 08:32 am
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
free transmissions
Date: 11/28/2019 10:21 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 1,722
  • Online ever: 1,722 (Today at 02:19:48 AM)
  • Guests: 488
  • Total: 488
5 lug swap: junkyard question
Started by SD44, December 02, 2007, 10:13:22 PM
I did not say the perches need to be moved.
Yes, you could MAKE it fit without modifing or moving the perches, but leaf springs are prone to binding and breaking with side loads. It might also make changes to how the car handles; I am not saying you should not do it, it's just something to think about.
The 72 Maverick rear is actuall 3/8 of 1" narrower.
Everyone here says you have to move the pearch.
I just spread the leafs out a bit and it bolts right in.
The brake lines are
harder that bolting in the housing
SD44
Quote from: Pintony on December 04, 2007, 10:26:37 AM
Then swap the rear to a 72 Maverick V8 5 lug rear.
have you put a 72 Maverick rearend under yours?  was it not too wide?  we have a few early 70's mavericks is why i ask.
Quote from: SD44 on December 04, 2007, 10:08:36 AM
...I think we would be just fine by simply replacing the rotors with the Mustang II 5 lug rotors, we're not going to a larger engine or anything.  We're gonna look around and see if we can find a junk Mustang II somewhere and get the rotors and rearend.  Is the Mustang II rearend a direct bolt-in?
As mentioned, Mustang II's are not 5 lug, and all the brake parts are IDENTICAL to the '74 and later Pintos'.
BTW: Not all Mustang II's have the 8" rears.
Yes the MII is a direct bolt-in but they are 4 lug.
Just buy the rotors from the link I posted.
By the time you find Junk Yard rotors and drive them to have them turned. It will cost the same as NEW.
SD44
For your guys' information..........yes the 74-up Maverick disc brake system (rotors, spindles, calipers, etc) is the exact same thing as the Granada's.  I have quite a few 66/67 Fairlanes and the Granada/Maverick swap is a common braking upgrade that we do on these cars and also Mustangs.
Here is our Fairlane site:
http://www.woodyg.com/fairlane/
Thank you guys so much for the valuable info.  I think we would be just fine by simply replacing the rotors with the Mustang II 5 lug rotors, we're not going to a larger engine or anything.  We're gonna look around and see if we can find a junk Mustang II somewhere and get the rotors and rearend.  Is the Mustang II rearend a direct bolt-in?
Quote from: 77turbopinto on December 03, 2007, 09:03:26 PM
For a SIMPLE, LIGHTWEIGHT, + DEPENDABLE caliper to swap.
Now U sould like the Street Rod guys.
Y don't U go put a bowtie engine in your Pinto!!!! :P
Quote from: Pintony on December 03, 2007, 07:45:42 PM
Y would anyone put a GM part on a Ford??....
Don't get me wrong, I would rather have Ford ones, but.... (see above).
Quote from: SD44 on December 03, 2007, 03:35:58 PM
those links were helpful, but still didn't clear everything up, maybe I'm not reading closely enough.  As for what 80's GM cars have the correct metric calipers, one poster mentioned that he used 83 Monte Carlo calipers; I know we have an 84/85 Buick Regal, so I'm sure it probably has the same calipers since the Regal/Monte Carlo/Cutlass were all basically the same car in the 80's....
Those SHOULD be the ones. Maybe you can contact them for a part # or take one of the brackets to the yard...
....So the Maverick and Granada rotor will work right on the Pinto spindle, correct?  Will I still use the Mav/Gran races and bearings, or are the bearings different to accomodate the Pinto spindle?.....
Yes, IF Mavericks have the same rotor as a Granada, + yes; all you need to do is remove the shield and they go right on.
....So, from what I read, a 68 Mustang 8" rearend is a good choice to use for a 5 lug rearend....
Only IF you want one that wide.
If you use the rotors in my post. you do not need anything else!!
SD44
So, from what I read, a 68 Mustang 8" rearend is a good choice to use for a 5 lug rearend?  We have quite a few 66/67 Fairlanes, I'd bet we could use one of those also since we don't have any Mustangs.
Quote from: SD44 on December 03, 2007, 09:37:20 AM
question: were all of the mustang II's 5 lug?
No Mustang II's were 5 lug, they were all the same 4 lug as Pintos and Fox bodies (less the SVO).
SD44
Sounds like you are looking for the 5 lug conversion, not necessarily the BIG brake rotors.
Here is a link to an EbaY AUCTION for the 9" 5-lug rotors stock replacement NO modifications necessary.
http://cgi.ebay.com/ebaymotors/Mustang-II-ROTORS-NEW-Street-Rod-Ford-5-lug-pair_W0QQcmdZViewItemQQcategoryZ34199QQihZ021QQitemZ310004032269QQrdZ1QQsspagenameZWDVW
Quote from: SD44 on December 02, 2007, 10:13:22 PM
.... We don't have any 4X4 Blazers, so we'll have to buy the brake lines.  Is it the big Blazer or the S-10 Blazer?....
http://www.fordpinto.com/smf/index.php/topic,1103.msg14627.html#msg14627
EDIT: I had two posts in that thread, one I was not clear (has been changed), but the other had a link to the FULL details where I stated what Blazer and more:
http://www.fordpinto.com/smf/index.php/topic,1103.msg9727.html#msg9727
....Finally, what 5 lug rearends (granada, maverick, etc) are used to upgrade to the 5 lug?  Is there any narrowing or modification needed for the rearend?
http://www.fordpinto.com/smf/index.php/topic,953.msg28709.html#msg28709
SD44
hi, new to the site, this is my first post.  googled and found this site so we can do a 5 lug swap.
We're wanting to upgrade to 5 lugs on our 79 Pinto.  Okay, i know about the rjays swap:
http://rjays.com/Brakes/MII-Brakes-01.htm
Now, we have a 300 car junkyard, so what i'm wanting to do is get these parts off some of the stuff we have.  we have some granadas, mavericks, celebritys, 6000's, calais, etc.  So, can someone tell me - or leave a link - what model GM cars have the metric calipers that we can use?  Also, what year Maverick/Granada's should I get the rotors from?  We don't have any 4X4 Blazers, so we'll have to buy the brake lines.  Is it the big Blazer or the S-10 Blazer?
We were told that there is also a 5 lug upgrade using Ford Ranger brake components, yet I couldn't find any information on here about that.  anyone ever heard of this?
