Date: 05/13/2021 05:29 pm
V8 rear end
Date: 04/12/2018 10:57 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
v8 springs
Date: 05/07/2017 04:46 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 02/27/2017 10:10 pm
Date: 01/19/2020 09:06 am
Date: 04/14/2023 06:15 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
  • Online today: 1,722
  • Online ever: 1,722 (Today at 02:19:48 AM)
  • Guests: 1669
  • Total: 1669
stalling.........Ignition problem????
Started by EMTcop, November 25, 2007, 10:11:06 PM
I had that problem with a few new modules too. But they always tested good. It wouldnt always restart afterwards but it would alot of the time. Finally one time it happened and wouldnt restart so i went out and unplugged the module and then plugged it back in and it was fine. Actually dont think ive had any problem with it since then. So that was a bad connection issue it sounds like. When replacing the module i would clean up the connectors and terminals real good and put new dilectric grease on them. That will probably prevent that from happening.
bob55
I had the same thing happen with a '75 Mustang II 2.3 that I had.  It was the ignition module that was bad, and I had a run of two or three of them that would last a couple of months, and then the same symptoms.  Finally got lucky and got one that worked.
Bob55
In a quandry......
earthquake
I agree with pintoguy76,It sounds like the module.After having this happen with 2 different modules we went to points.No more problems
 ;D ;) :lol:
Quote from: EMTcop on December 01, 2007, 01:03:44 AM
Its a 1980
It had to be a late Pinto!!!
See how the bumpers stick out so far they won't even fit in the photograph of EMTs avitar... ;D ;D ;D
Make sure you keep us informed. So that we can be confident that the suggestions are accurite.
EMTcop
1980 Ford Pinto
1999 Ford Crown Victoria
2002 Pontiac Firebird Conv. 16k miles
2007 Toyota 4runner
What year is the car?  I cant tell from the pic. If its 75+ (or a 74 with electronic ignition) it could be the ignition module making it do that. Tho when its the module sometimes it wont restart right away. But it could.
 Could be the PU in the dist
The Coil is most likely OK.
Do the easy stuff first.
Pull the air cleaner when cold and warm to normal temps to make sure the choke is working properly.
Drive the car untill it stalls and check the position of the choke plate B4 restarting.
If the choke plate is shut then you have found your problem.
To set the choke drive your pinto untill quite warm and then adjust the choke to where it just starts to close the plate. then back off 1/2 notch.
Could be that the reo-stat has broken inside the housing.
The choke linkage may also have some slop,so check that.
AGAIN this is the easy stuff B4 you spend money on parts that do not fix the problem.
If all is ok?? Replace the ignition module on the drivers inner fender.
Pinto Pro
Either the magnetic pickup inside the distributor is going bad, or the coil is going bad.
I've had both happen to me
EMTcop
Quote from: Pintony on November 25, 2007, 10:16:00 PM
Does your Pinto re-start after stalling???
yep! everytime, it just shuts off(just when I usually say " oh its running smooth now" LOL)
1980 Ford Pinto
2007 Toyota 4runner
EMTcop
I noticed last night when I took the blue beast out it keep stalling, not like a gunked carb stall but like the car just shuts off? The longer I drive it gets better. Could this be an ignition problem? Ive changed the plugs & wires & distributer? any suggestions ???
1980 Ford Pinto
2007 Toyota 4runner
