Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 10/03/2018 10:46 pm
Date: 09/12/2018 12:33 pm
Date: 11/12/2020 08:28 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 11/08/2020 02:10 pm
  • Online today: 489
Wet Floor
Started by Smeed, November 17, 2007, 01:56:21 PM
Starliner
I agree with "aPintoNut", this is the first place I would look.
I noticed that my 73 Pinto was leaking water half way down the window seal on the passenger side of the interior.   The water then dripped down on the door sill area, then to the floor.   I was lucky because I do not have carpeting.   My guess is that my leak was further up the window seal and the water followed it's way down.
My car is not rusty and the rubber felt good, so I don't know why it was leaking.  I treat my car as a low cost driver and not as a classic.  So all I did was buy some some flowable silcone windshield & glass sealer and got it to flow behind the metal trim.  So far this bandaid repair has worked.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Smeed
Ill try and look for a hole. This car came from new mexico so Im thinking its the rubber leaking because its dried up. Ill definitely take a look into both though.
'73 runabout
UltimatePinto
If the leak is coming from the core, I would guess that  you should be able to smell antifreeze.
I have a 73 Runabout that sat outdoors for too long and the vent sheet metal, (below the windshield, under the louvers), rusted and that is where my leak came from.
Located on the passenger side, the heater assembly attaches to it with a soft rubber doughnut between heater and body.
I welded as much sheet metal patch as I could to fix the problem. Only trouble is there was not a lot to weld to. Will use bondo to fill in the rest
Al
apintonut
this is most likely from the windshield all mine have leaked there.   time for some new rubbers
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Smeed
The passenger side floor is wet, right under the vent and in the heater core area. Most of the wetness seems to be to the left side. Im pretty sure its not the heater core because its only wet after its been rainy. Its been wet on the driver side as well but it seems like after I closed the vent its been fine. I looked on the underside of the piece of carpet Ive got on the floor and could see an outline of where it was wet. Could it be the seal around the windshield? Can the water be coming down the air vent somehow?
Here is a picture, Ive shaded the wet areas in blue.
http://img132.imageshack.us/img132/4567/wetjq2.jpg
'73 runabout
