Date: 07/01/2019 12:23 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 04/20/2017 08:56 pm
Date: 09/15/2019 08:30 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 08/22/2018 09:23 am
Date: 09/03/2018 08:58 am
  • Online today: 489
  • Guests: 218
  • Total: 218
Faded Woodgrain Tricks??
Started by Jamie Plastic, November 13, 2007, 11:29:29 AM
Jamie Plastic
Thank you so much....You too Bill...no worries on the rubbing compound..I did just a very small part about the size of a quarter. I will go out and get some tonight!
Hope it works as good as your, cause the car really looks nice when the woodgrain is all even.
I will keep you posted!
Jamie
1971 Ford Pinto Runabout
1960 Ford F100
1965 Mercedes Fintail 220S
1966 Mercedes Fintail 200
1965 Mercury Montclair Breezeway
1965 Ford Country Sedan Wagon
1974 Lincoln Mark IV..Stunning 41XXX original miles
What   did i here my name ?  yes there is a trick to bringing it back. Hopefully the rubbing compound did not hurt it. wash it  using a gentle brush to clean out the "pours".  dry lightly and use eagle one wet wax now called  wax as you dry . in a blue spray bottle. spray it on a rag and wipe on the vinyl  wood grain.  keep reapplying every day or 2 and it should get better . i did see some results  right a way     but it just gets better  every time.
Mine was very dull  no luster and sort of rainbow in color when i  started.  last year i was at a judged show and the judges  said they had never see 30 yr old   applique look so good. they  though it was replaced.  :smile:
You NEED to talk to PhilsToys!
Jamie Plastic
Hello,
On my 1976 Bobcat wagon the the upper half of the woodgrain is really faded. When it gets wet it looks good. On my Roommates Pinto Squire he uses Armourall and it works pretty good...Does work on mine though.
I tried a very light rubbing compound to see if it is just oxide, but that didn't work either.
Does anyone know any trick to brighten that back to new?? Is there a place that can replace it or some where I can get the replacement woodgrain and do it myself??
HELP!
Thanks
Jamie
1960 Ford F100
