1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Date: 04/08/2018 05:47 pm
Date: 03/16/2017 10:00 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 03/13/2021 12:57 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
  • Online today: 802
  • Guests: 475
  • Total: 475
Tech question about header on 2.3L motor
Started by popbumper, October 26, 2007, 11:13:40 PM
Yes, you are correct they could be for the air (smog) pump. I never looked to see what one they were connected to. Either way they are strictly an emissions thing.
Thanks,
Pinto Pro
Actually, I believe those holes are for air injection into the exauhst stream as part of the emission control system.
The extra oxygen in the hot exauhst helps burn off more of the unburned fuel before reaching the catalytic convertor.
Answers:
1) EGR. This is were some of the exhaust gas was taken to be put back into the intake for lowering emissions.
2) On a fully stock engine with a GOOD converter, or a N/A engine with limited performance upgrades and a GOOD converter, maybe a little, but IMHO not anything you would notice without a Dyno. The 2.3 head ports and manifolds all tend to be very restrictive, so the muffler and a good converter do little to 'hurt' unless other modifications are made.
3) If the engine is tuned specifily for it, the engine should have outlasted the occupants of the car (breathing the exhaust). I would think that the exhaust valves would be the most at risk for damage.
Guys:
  This question has bothered me for years. Before I begin, the disclaimer is this - I have never rebuilt a motor, and would not know how, but I HAVE done a frame off restoration on a 1957 Chevy - so I do have good general knowledge about "this stuff", just not intimate details of powerplants and drivetrains.
  Back in the early 80's, when I owned a 79 wagon (2.3L motor), I "treated" it to some basic touches to improve appearance/performance. These included fog lamps, stereo, 13" and 14" mags, raised whites, blocked out rear windows, a SuperTrapp muffler, a Holley carb, and a header. I wanted to add a header, so I enlisted a friend who had the know how to help me install it.
  This is where the conundrum happens. The exhaust manifold of the block had four ports (obviously). Above each of these ports was a smaller hole, as I recall about 1/2" to 3/4" in diameter. As we installed the header, I immediately noticed the header had no provision for these small holes (only the main ports), where the stock manifold DID scavenge these holes.
Let me tell you what...I did NOT run the car for long in this manner, but the reduction in backpressure and effect of letting a small amount of exhaust right off the head made AMAZING horsepower  :surprised:! After a week of real enjoyment (seriously - it made a big difference) I thought it was best to plug these holes, so we jammed large bolts up into the holes and cut them off, sealing the holes forever.
OK, tech guys:
1) What were these holes for?
2) Would the increased horsepower be a result of the exhaust not having to travel through the catalytic and muffler?
3) What would this have ultimately done to the cylinders/motor if they were left unplugged?
...and there you have it. Please help me answer a question which I have wanted to know for many years!
