Date: 10/01/2020 02:00 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 02/05/2017 09:45 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 04/04/2020 09:38 am
  • Online today: 1,090
  • Guests: 143
  • Total: 143
Back Hatch Window
Started by 77pintocw, October 05, 2007, 09:26:20 AM
Popsicle stick R too flimsey,
I use the "Pinchy" kind of clothes Pins.
I thake out the spring and have 2 strong "Hard Maple" wedge-pinchbars to ease out hte window.
I have a 71 that has gaskets so hard that I will need a cold chizel to remove the glass.
Good idea's oldkayaker.  You are probably correct about the screwdriver but so far I have not messed anything up using my screwdriver.  I think I will switch to popsicle sticks to be sure ;D
Adding to what tigger said.  First I like to lubricate the inside portion of the gasket with Armorall.  It makes a mess but lets the gasket slide out easier putting less strain on the glass.  Second I use popsicle sticks as wedges instead of screw drivers.  I have had bad luck with screw drivers and glass.
Usually you can just lip the gasket over and push.  It is easier if you have a friend helping but I have done it by myself.  Sometimes a small screw driver helps to keep the gasket from coming back over the lip.
77pintocw
Hi Folks:
What is the trick in getting the back hatch window out in a wagon without breaking the glass or damaging the gasket?
Thanks for your help.
77pintocw
1977, Pinto Cruising Wagon, White with Blue Graphics
