Date: 10/24/2018 07:35 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 06/12/2018 08:18 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 07/30/2018 04:32 pm
Date: 07/04/2022 07:55 pm
Date: 02/18/2017 04:47 pm
  • Online today: 452
  • Guests: 390
  • Total: 390
Cant get pinto started. Been sitting 16 years. - Correction, it started!
Started by pintoguy76, October 04, 2007, 05:49:28 PM
Don't get too upset over the readings. PROPER readings need to be made with the engine fully warm and with WOT. It should run on ether even with those numbers.
Adding oil will only work for the test, and only for a short time too. As far as running, it will burn off or foul the plugs.
Yamaha sells (and maybe others too) a GREAT additive to free stuck rings. That stuff has done wonders on a few bikes I have had over the years.
Get good spark, get it running, then warm and re-check the comp.
Quote from: crazyhorse on October 04, 2007, 09:57:11 PM
Put a little motor oil down the spark plug openings. This will help seal the rings. If it's been sitting there's a real posibility of corrosion inside the cylinders.
The epoxy running out of the ignition box is a BAD thing. That means it got hot. Most likely it's toast. My '74 was converted to duraspark, I melted down the box, but still got intermittent , weak spark. Not enough to run though.
Hope this helps.
Oh believe me the ignition box is still getting hot :D lol. So is the coil. But i just got in from testing  stuff, the ignition will still throw a blue spark about 3/8" wide on the tester i have. I didnt open up the gap any further to test but i figure if it will gap 3/8" with a blue spark, it should do well enough in the spark plug in the cylinder, too. You could be onto something with adding oil into the cylinders. I also tested compression sucessfully this time and this was the sad results:
#1 - 30psi
#2 - 70psi
#3 - 70psi
#4 - 60psi
I suspect the lifters arent working right, or the valves are stuck a little or something like that. I checked the valve timing and ignition timing (#1 piston @ TDC on compression stroke, verified the cam sprocket was in the correct position, and that the rotor was pointing to the number 1 spark plug tower on the cap) All was good there. The firing order is correct, i verified that as well. I will definantly try putting oil in the cylinders as that should boost the compression to a level that would allow it to start if that is the problem. After sitting 16 years it very well could have lost all the oil from the cylinder walls and that would explain the drop in compression. It ran when it was parked is what i was told, the guy said he parked it because either the engine or the trans was knocking. So it had to have had good enough compression to run, then.
I'll replace the control module and coil when i get the money but that may be a little while. Still seems the spark it has should be enough to fire the engine to me but i could be wrong i guess.  It did hit a time or two...
Thanks for the advise guys. I'll keep you posted.
Hope this helps.
No didnt do the cranking all at once. i gave it a rest for a few seconds after every try. I tried a compression test on the #1 cylinder and it wouldnt blow anything on the guage. It did however release a little bit of pressure when i pushed the release button. I dont know if maybe my compression guage has a problem (i just bought a cheap chinese made guage from harbor freight) or if the engine really isnt blowing any compression. When i took the plug and the guage out of that cylinder and cranked it with the hole open i did feel air coming out.  I am kind of thinking that there is a problem in the head somewhere.  As i said the engine doesnt sound the same while cranking as the same engines do in my other two pintos. A cylinder that wasnt compressing would make the engine turn over faster atleast from my experience which makes it sound different, and this one actually seems to be turning a little slower. Is it possible the distributor could be causing the module and coil to be getting hot, or is it likly the module? I'll look for damaged wire and things but i think its all good. I'll check the rest of the cylinders with my guage, and my other pinto, to see if i get any readings. Then i'll know if the guage works or not.
Start with the basics. You never know what other people might have done 16 years ago and forgot, and/or are afraid to tell you about.
The car is in a fully unknown condition. If It were mine, and it would not start with spray ether, I would check for spark, valve timing, ignition timing, and compression (maybe not in that order).
If all that checks good it should run, at least on ether (or carb. cleaner).
That ignition box sounds like it has issues. I would LOOK VERY WELL at the entire engine harness for a possible cause (damage to the wires,...). I would hate to install a known good one to test, and have the car do that to the good one.
Did you say you were CRANKING it for a few minutes? All at one time? If so, not good. Give it a good rest after 20 seconds or so.
Almost anything electrical that is hot (without the engine running) has either a short or a bad connection, maybe both.
As youve probably seen me post, i picked up a 79 pinto (2.3/auto) last saturday thats been sitting for 16 years. It ran when it was parked but had a knock in the engine or the transmission i was told. I cant get it started to find out for sure whats wrong. I put on a carb from my 76 that i know works (drove it around just earlier today lol) and hooked it up to an electric fuel pump. I know it has fuel. I tested the spark and it did light up the bulb, but it was pretty dim. I noticed the coil and the control module were very, very, hot. All i'd done was crank on it for a few minutes. I removed the control module a few days ago because i had noticed sticky stuff had run out from behind it. It was like that when i picked it up so its been that way 16 years. I think that either there is not enough spark to start it (tho it did hit a couple of times) or there are some valves froze open or something. It doesnt sound the same as my 74 and 76 and they are both 2.3s also.  I've seen a little smoke linger in the throat of the carb but no backfiring or anything. I adjusted turned the distributor as far as it would go in both directions a little at a time and it doesnt seem to help any. It would stumble some when i pushed it up close to the block tho. I am kind of at a loss here because i KNOW its getting fuel, its getting spark (maybe not enough volts?), and air (obviously) and its cranking over... so theoretically it should start right? Like i said i suspect stuck valves, or the distributor/control module/coil is bad (one or all three). What do you guys think?
