1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Hatch needed
Date: 09/10/2017 09:16 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
77 pinto
Date: 08/22/2017 06:31 pm
Date: 02/05/2020 11:06 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 04/12/2017 06:57 pm
  • Online today: 1,090
  • Guests: 767
  • Total: 767
oil tube
Started by 80bobcat, October 04, 2007, 12:57:11 PM
80bobcat
Ok thanks..I`ll have to rig something up as a bracket..and I may JB Weld it in place..I`ll see when I rig it how secure it is the motor isn`t in yet..
Look Officer..it`s a Pinto would YOU stop short?
When I build fresh blocks, I use JB Weld to secure the tube.
Not sure U could get a block clean enough to do this while still in the car????
The oil tube is a friction fit.  It should have a tab that is supposed to bolt to the intake manifold to keep it in the block.  I would make it removeable as possible as you never know when stuff will happen.
80bobcat
Hi all....the oil tube.. does it have an O ring where it goes into the block? or is it friction fit? It`s an `80 Bobcat  with an `87 merkur motor I`ve done the swap with the plugs.. rear for front...now the tube sits very loose.
If it is friction fit ..anybody have any ideas? I was thinking of JB weld or along those lines
all input is welcome.and TIA
PS: I`m hoping to get the turbo project back on but things are going slow
