1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 12/20/2016 10:47 pm
Date: 07/17/2019 05:23 pm
Date: 04/15/2017 05:14 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 10/04/2019 08:43 pm
Date: 05/13/2021 05:29 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
SVO SWAP
Date: 03/15/2018 03:12 am
  • Online today: 802
  • Guests: 102
  • Total: 102
Mobil 1 comments requested
Started by Starliner, October 03, 2007, 12:39:12 AM
Starliner
High Horse,
Thanks for the great BTDT information.  When I get back to the states I will check that.  At 33,000 original miles I hope that is not an issue.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Starliner,
    It would be the back corner of the head gasket where the oil is pumped up into the head. There is only about a Quarter of an inch of gasket on the two sides of that back corner. You can look at that back corner and see if there is any signs of oil seepage because that back corner will be wet.
If the corner is dry then you are good but if you see seepage then there is a good possibility that your camshaft might need to be  cleaned out and the lube holes opened up.
Starliner
Hello High Horse,
Are you saying that the head gasket can fail or a different gasket ??
StarLiner,
       I would like to start by saying that the 2300 motor has a darn good  oil pump. This is an asset and this can be a liability. Asset good oiling. Liability...if the engine does not warm up enough to thin out or to thick an oil relative to outside temp. then the gasket will fail at the feed port at the back driverside corner of the head as per the accompanying picture. Wives generally don't give the car a minute to warm up.
Because the camshaft is hollow to allow oil feed thoughout the head it is very hard....the cam follower will wear long before the cam lobe ever will.
Because the camshaft rotates and acts like a centrifuge I would not put any oil in the car that has additional particulate matter because it will collect and plug holes. I would use 10w30 with no more then 1 tablespoon of STP.
I think Mobile used to have a Teflon laced oil that caused a bunch of problems.
Starliner
I use Mobil 1 15W-50 on my 73 Pinto 1600.   I use the 15W-50 Mobil 1 because it has more zinc to protect the camshaft.  The other Mobil 1 grades do not have the extra zinc.   I have read that 1600s are prone to camshaft wear.   This oil also fit's my style of long distance freeway driving.    I baby it until it warms up.   So I am OK with this selection.
Now here is my question.   I also have a 79 Pinto 2300 automatic for wifey.  She just makes short trips and it will soon get cold.   I installed Mobil 1 10W-30 for this reason.   However I now have concerns about camshaft wear.
How are the 2300s for camshaft wear.   Any history of worn 2300 camshafts in 79 ????
