Date: 08/13/2018 02:46 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 04/12/2017 06:57 pm
Date: 04/14/2023 06:15 am
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 11/08/2020 02:10 pm
  • Online today: 445
  • Guests: 146
  • Total: 146
Rod Knock???
Started by Pintony, September 28, 2007, 03:02:00 AM
Quote from: Pintony on October 09, 2007, 08:03:29 PM
Hello SRT,
This engine is for my all original Green Pinto...
I am running the stock intake and exhaust manifold. in an Automatic transmission car. To do any porting on the head would hurt performance.
The engine ran good B4 the head gasket blew so now that the bore is fresh and the valves will have fresh seats it should run better than ever..
I am hoping to get the best running "STOCK" 2.0 I can have for reliability.
the only change I am making is to the CR, as I think that 8:0 to 1 is too low.
The 1971 2.0 was rated at 100HP and 9.0 to 1 CR. I am looking to get my CR up a bit and that 100HP would be fine with me....
That 100 is at the engine not the rear tires so YES it will still be slow.... :police:
tony i don't think it will hurt at all.  especially if you concentrate on the pocket under the exhaust valve.  you're eliminating a restriction which will flow more volume through the port into the manifold with out losing the velocity of the exhaust gas charge.  throttle response will improve as will power and mileage (if you make a concerted effort to drive for mileage)
i did pretty much the same on my girlfriends '72 back in '72. ( cut the head, recurved dist)  her car had the automatic (with the 'right-off-idle stall speed convertor) and a 3:18 rear gear and it really woke up that car.
You may be incorrect here Dave...That would be a Knod Rock. :read:
Original74
I think the knock is the rocks in Tony's head rattling at high speed!
1976 Runabout, project.
Hey earthquake,
I had another subject line "Well there's your problem"
I bumped it for U.
earthquake
Did it blow between 2 cylinders.That will knock like crazy.
Quote from: earthquake on October 15, 2007, 12:27:43 PM
Hey Tony
         Did you find the knock.
Hello earthquake,
The only thing I found was a head gasket blown.
SO FAR... everything else has checked out OK.
AGAIN I have not re-assenbled the block to know how the bearings will check out.
I will keep everyone posted as I do the rebuild.
I prefer to deck a block than a head for compression...I take as little as possible off the head...
Paint it pretty Tony...
Frank
earthquake
Hey Tony
Hello Group,
Here is a photo of my Green Pinto's 2.0 block just back from a fresh hone and a -.010 deck.
Everything checked out OK. New freeze plugs are also installed.
I picked up my engine block today as a present to myself...
The top of the block was out by .008 so the -.010 just took care of the shade tree IDIOT that replaced the head gasket.
Quote from: srt on October 09, 2007, 05:16:28 AM
take a grinder to the valve pockets while you have it off
Hello SRT,
Thanks Tigger,
I have most of the parts cleaned and ready for primer and paint.
I am real anxious to see how the Green Pinto runs after this...
Hopefully real peppy!   :fastcar:
I having -.010 taken off the block and -.010 off the head so I should be up to a good 9.0 CR when I'm done.
I will also do  a tranny flush, filter,& gasket while I have the Pinto down for repair.
I want to take the Mustard Pinto and the Green Pinto to the strip and race them.
Everyone in St louis will be talking about it for weeks....
The engine compartment looks darn nice!  Interesting trick with the brake fluid.  I will have to remember that one  ;D  One up for Pintony.
hELLO gROUP,
hERE i HAVE REMOVED THE ROCKERS FROM MY 2.0 HEAD SO ALL THE VALVES WOULD BE CLOSED.
i FILLED THE CUMBUSTION CHAMBERS WITH BRAKE FLUID.
AS YOU CAN SEE IN THE PHOTO ALL BUT #2 CYLINDER HAVE A leak at the exhaust valve. The valve seats will also get some attention as will the valves.
The intake valves seem to be holding back the brake fluid.
Hello Group,
Here is the fresh clean engine bay from my Green 72 Pinto.
I'll pick up my block from the machine shop on thursday with a fresh hone on the cylinders. "They were only .001 out." and a fresh deck on the block...
Once home I will install NEW rings and bearings and all NEW gaskets and seals.
I will drop my Cylinder head at the same time I pick up my block for a fresh deck and a good cleaning.
I hope to have the engine painted and ready to install B4 the snow flys so it will be ready for the spring show season.
I'll keep you guys posted with photos and my progress..
Good Luck, I am sure you will git r done 8)
Hey Tigger,
Yes my Plan is to re-build the original block and head to factory spec. except for a -.010 head shave to bring the C.R. up a bit.
I will also have hardend exhaust seats installed so I do not have to buy leaded  racing fuel to blend with un-leaded to keep the valves happy...
I just hope everything goes smooth tomorrow so I do not have to leave this Pinto behind...
I have a Hot Rod 2.0 on the engine stand.
I will be installing the engine that I took out of the Purple Pinto.
It is a High comp block + cam an oversize valves.
I hope the cam is not too big for the automatic...
I would just install a NEW crank... I have several already ground 10-10 and bearings on hand. BUT I need to flush the engine oil gallerys as I found junk in the pan,
Anyway wish me luck!
That sucks.  Are you going to repair the original engine and put it back in eventually?
Hello group,
Getting ready for a show tomorrow I washed and waxed my all original Green Pinto.
The Pinto I had at Carlisle and Tulsa..
Well for NO reason the engine developed a Knock today about 6pm?
Again there is NO reason for the knock so I am confused It was running perfectly fine at 5:30.
The oil was about a quart low but I got no light??
Anyway I'm done for tonight I hope to have the NEW engine in & ready for the show  by tomorrow at 3:00 or I will only have 2 Pintos at the show... This Pinto has been there 5 years in a row...
I'll let you guys know what I found on sunday after the show...From Pintony
