looking for parts
Date: 06/19/2020 02:32 pm
Date: 12/04/2018 07:40 pm
Date: 10/02/2017 02:16 pm
Crane Cam
Date: 02/26/2018 07:50 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 04/13/2018 11:30 am
Date: 08/27/2018 11:11 am
Date: 04/28/2018 04:12 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
  • Online today: 500
  • Guests: 325
  • Total: 325
Rod Knock???
Started by Pintony, September 28, 2007, 03:02:00 AM
Hello Group,
I have my air cleaner lid & rocker cover blasted and scrubed up with soapy water and heat dried to remove any water dropplets.
Ready for prime coat
I got the lid a bit HOT!!! ;D
QuoteWhe re can I get one of those Early American Arts and Crafts Movement Hydrocarbon Free Release Valve Covers?
Say that fast five times... ;D
Boss2300
Well i am way behind on my projects. It has been a busy winter with work (hospital) & family stuff going on & when i get a little time i seem to end up helping my buddies with there projects. I have to get moving soon on my own stuff.
'I pledge allegiance to the flag of the United States of America and to the republic for which it stands, one nation under God, indivisable, with liberty and justice for all.'
Thanks Dennis!
How is your project coming?
Boss2300
NICE job. Let me tell you it is harder to restore a car to original than it is to hot rod one. I have been there. Hot rodding is EZ. Buy the right combo of parts & put them together. To restore one with the correct factory paint & coatings & markings takes a lot of research. Looks like you did your research. Way to go Tony.
           Boss2300
Here are some of the parts I have ready to bolt on.
Thanks HH!!
71HANTO, I am trying to duplicate EXACTLY what Ford did. Even the locations of the different color markings.  I'm using my 28,000 mile 71 for referance.
Using all NOS or reproduction items. The heat shiels is the wrong color for 72. it is supposed to be Blue, so I will rectify that.
Every bolt is being painted to match what ford did in color the bolts that did not have color I am using clear coat to keep them looking fresh.
When finished I am hoping for the WOW! affect from show attendees...
This process is taking much longer thaI expected. Hopefully it wil be worth all the time spent making everything perfect.
Will keep you guys posted as to my progress.
If you look closely there are fuel stains on the carb. Must need a top gasket???
Glad you guys like it!!!
P.S. Notice I used the FACTORY bracket to hold the head pipe in place as well as the ORIGINAL double hump exhaust clamp.
Factory = NOS
Original = Reconditioned factory installed
The Green Pinto still has the ORIGINAL 1 piece exhaust system.
Pintony,
REALLY NICE......and that Pinto has earned it's STAR Treatment. It needs it's own Trailer...Makeup?..Wardrobe?? "Mr. Demille" !!!
One question...Where can I get one of those Early American Arts and Crafts Movement Hydrocarbon Free Release Valve Covers????? :hypno:
Very Purdy Pintony....Your an artist.
Hello Group,
Finally got some good weather to get parts painted so I could start the re-install of my Green Rollin-in-my-Pinto's Engine.
Here is a photo or two...
Quote from: Boss2300 on November 12, 2007, 07:31:50 PM
  Hi Tony
    JB Weld on your  PVC canister-oil separator might work also.
Hey Dennis,
I used acid core solder and map gas to solder-up the leak.
In fact I soldered up the entire unit.
I can now get suction to hold on the breather. :)
Boss2300
  Hi Tony
Quote from: High_Horse on November 12, 2007, 09:25:10 AM
That is a good question Pintony. I know you want to replicate as closely as possible the originality of the car but after all that work would not a little longivity in prettiness be in order. I have some stainlless steel paint that I thought looked fairly metalic when applied. Shoot me your address and I will send you a couple of cans. ;D
Hello HH,
Thank you for your offer...
But if the head was painted it most likely was black.
Ok, so I got the Rollin in my Pinto's engine primed painted and got the head torqued in place + the cam installed and the rocker lash set.
The Member Pinto1600 works for Mac's Restoration,  he sent me some
"Cast Blast" high temp coating for my exhaust manifold.
WOW that stuff looks GREAT!!!!!
P.S. I wonder if the head really had paint on it from the factory or not???
I found my torq-wrench FINALLY after 2 day of searching so I torqued the rod bolts to 33 and the mains to 75ft.lbs. The oil Pump I torqued to 25ft.;lbs.
I got the oil pan installed + the water pump.
A little masking an I'm ready for primer & paint
The Green Pinto always had an oil leak that I could not track down..
This photo is the PVC canister-oil separator.
I found a leak in the area where you can see the bulge.
I'll try to get some solder in that crack before I install.
Looks good....nothing like a fresh head. Thumbs up.
I got thr 2.0 head for my Green Pinto back today..
Kinda Shiney!!!!
Can't wait to get this engine back together and do a BIG smokey BURNOUT!!!! ;D
Quote from: oldkayaker on October 28, 2007, 07:21:55 AM
The assembly is looking good.
Just wanted to make sure you were aware that the 2.0L crank thrust bearings can be installed backwards.  Unfortunately this engine is not made idiot proof here and sure enough I got one in backwards and ruined my crank.
Hello oldkayaker,
Hey!!! That is GREAT advice!!!!
You are 100% correct. The thrust bearing has to be checked carefully.
I can see how installing the block side could easily be installed backwards and ruin your whole month.
GREAT TIP!!!!
I think a 1-UP is in order! :D
Here is the B4 and after photo of the pistons after I finished cleaning them.
After assemblly of the block and crank, I cleaned up the old Pistons.
Here I am using a ring grove cleaner.
As the piston rings wear... Carbon fills the gap behind the ring.
IF this step is not done the NEW rings will not fit in the lands and it will be REAL HARD to get the pistons back in the hole.
Since this engine has only seen light-duity the buildup in the grooves were not bad at all.
Hello Group,
Finally got some time to start the build on my Green Pinto 2.0.
Here I have the crank in the block along with the rear seal.
I am re-using the old bearings as this engine only has 53,000 miles.
All the main bearings were between .0015 and .00175 all the way across the bearing surface,
I plasti-gage-ed all the main bearing and all the rod bearings.
QuoteFunny thing is,,, this engine already had oversize valve stems installed and it only has 53,000 miles.
That might explain the breeched head gasket. The one that failed in my car was a Felpro. The plot thickens.
Thanks Doug!
3 cylinders were only out by .001 and 1 was out by .002
A bone-head machine shop must have reamed for bigger valve stems and BOTCHED the job???
Thus resulting in the exhaust seats being beat-out beyond repair.
Quote from: Pintony on October 19, 2007, 01:41:45 AM
I have to have hardened seats installed on the exhaust valves
Just one of those cases of "you might as well"...
I am sure it'll be much nicer not having to add the lead additive every gas up.
Good luck Pintony!
--Doug
OK! First the good news...
The head is NOT cracked...
The bad news... The exhaust guides R shot and I have to have hardened seats installed on the exhaust valves
So it will be another week or so B4 I get my engine put back together...
Hello Group,
I forgot my phone today and when I got home I had a message from the machine shop had called about my 2.0 cylinder head.
I hope it is not BAD news like a Crack or something. :angel: :'(
I'll call in the morn and find out...
