1977 pinto rear bumper
Date: 04/19/2021 11:57 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 09/12/2018 12:33 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 07/30/2018 04:32 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 12/13/2016 10:25 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Radiator
Date: 05/27/2018 06:07 am
  • Online today: 583
  • Guests: 428
  • Total: 428
LOOKING FOR A RADIATOR
Started by tim 1223, September 20, 2007, 07:33:35 PM
tim 1223
Hello,  I called Northern Factory Sales, they said that don't carry that radiator anymore.  I appreciate all your help.  I decided to go with the 1968 mustang radiator. Thanks Tim
IIRC: The Modine numbers are the same. Also, when I got my '4banger with air' radiator from NAPA, they said the book showed the V/6 and the 4l with air to be the same radiator, and they are not.
The #426 is the 4L with air, just to let you know.
I would go with a older Mustang one if I were to do it again. Mustangs Unlimited has them for well under $200.
OK... Here's what I found...
The Auto Value next door doesn't show a part # or availability thru normal channels...
However in one of their extended options the Northern Radiator catalog shows a part # 427 for the Merc Bobcat w/V6. We called on Friday but computers were down and they couldn't confirm availability. They were to call back later but had not by the end of the day on Friday. I stopped in this morning and one of the employees gave me the name and phone # for the company who does list a part #.
It's Northern Factory Sales out of Wilmer, MN and 1-800-328-8900 and again the part # is 427
so with all this in mind you could....
1) You could try calling them on Monday for availability and to see if they will ship and sell directly to the public.
2) If they don't you could try calling auto parts stores in the area and see if they can get it for you if they can order from Northern Radiator.
3) Final option is to contact me and I can hook you up with the Auto Value next door as they can take orders and payment w/credit card over the phone and either drop ship (if it's an option) or ship the item once they receive it.
Hope this helps....
I know the upper hose on the 2.3 rad. is on the drivers side, and the 2.8 has it on the pass. side. I don't know about the lower, but what ever side the hose connects to the engine is where it should be.
That being said, I KNOW for a FACT that a 67-68 V8 stang rad. WILL DIRECT BOLT INTO a Pinto, you just need to see where the hoses connect, and what size. Flex hoses come with ends that are different sizes if needed. I say all this because there are a BUNCH of them out there and are fairly cheap, and had I known this before I......
If the immage in the photo is correct??
It "IS" the V6 rad....
I'll check in the morning and see what they can come up with...
tim 1223
Hi Brian,
                           Thanks for the E-bay listing.  The radiator they show is not the same one as the one I have.  They list this radiator will fit the 2.3 and the 2.8 motors, even though they are different . So I called them and they told me that's what their computer shows.  They could not tell me which sides the inlet and outlets were on. I think it might be the wrong one.  If you don't mind I would like to see what your guys can come up with.  Thanks for the help. Tim
Hey Tim from Minneapolis, Brian from Hibbing MN here... Not sure if this will help but found this on ebay. It may not be the exact part you need as it doesn't list the V6 Bobcat but I have often found if you contact the seller he may have the part you want and just not be putting them up on Ebay. Also because it does list the V6 Pinto it "may" work...
I will stop in the auto parts store next to work tomorrow and see what they might be able to find. I called and talked to the part-timers and they don't show a listing but if I stop in during the day and ask guy's that know their stuff they might be able to find it in their extended options... pulled rabbits out of their hats for me many a times...
http://cgi.ebay.com/ebaymotors/Mercury-Bobcat-75-76-77-78-79-80-Radiator_W0QQitemZ320147804432QQihZ011QQcategoryZ33602QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
This is a brand new, in-the-box Radiator that fits the following vehicles:
1975-1980 FORD PINTO 2.3L L4 (1975 1976 1977 1978 1979 1980 )
1975-1979 FORD PINTO 2.8L V6 (1975 1976 1977 1978 1979 )
1975-1980 MERCURY BOBCAT 2.3L L4 (1975 1976 1977 1978 1979 1980 )
Radiator Specs:
DPI #: 426
Reference #: 0426
Height: 16.37"
Width: 20.25"
Depth: 1.25"
Top Header: 3 1/8" x 20 1/2"
Bottom Header: 1 5/8" x 19 3/4"
Inlet: 1 1/4"
Outlet: 1 1/4"
Core Type: Solid core radiator
Transmission Oil Cooler: 10"
Engine Oil Cooler:
Special notes for this part:
None
The product is OEM-style aftermarket and meets the OEM specifications of the original radiator.
Serial #:
RHGLMZ-1-75
This part replaces parts with the following OEM #:
D52H8005KA
tim 1223
Hello,  Does anyone know where I can buy a new radiator for my 1978 Bobcat.  It has the 2.8l v6 with a/c.  I live in Minneapolis and all that I can find are radiators for the 2.3l.  Any help would be great. THANKS Tim
