1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 05/22/2018 01:54 pm
Date: 08/02/2019 04:18 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 09/22/2020 11:33 pm
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Date: 03/06/2017 01:19 am
Date: 04/21/2017 02:03 pm
  • Online today: 1,293
  • Guests: 154
  • Total: 154
Car is Overheating! HELP!
Started by Trigger01, September 10, 2007, 08:04:38 PM
Trigger01
LIke I said above I forgot to get more coolant while I was at the auto parts store, so I picked it up Friday on the way home, but it was still raining. I put it in on Saturday morning  think I would be able to drive it out to my parents house. that didn't happen. The guy at AutoZone gave me the wrong gasket. I ordered a new one(hopefully the correct) on Saturday and picked it up today. I won't have a chance to tear into it until Thursday. I am hopeing this will fix, I really wanna drive my Pinto!
-Mike
MCarrTrigger01@aol.com
SOLD
1978 Pinto Runabout
2.3 liter 4-cylinder
4-speed manual trans.
Daily Driver:
Heavily Modified Lifted '01 Ford Ranger Edge
Trigger01
Alrighty, sorry i haven't gotten back with ya'll I've had Finals and papers this past week.
Tonight I replaced the thermostat, that was messy! lotsa greese! I forgot to get more coolant at AutoZone the 2x I was there today. I am gonna get it tomorrow and teat it out this weekend, Thanks for the help and I'll let yall know how it works out.
-Mike
SOLD
1978 Pinto Runabout
Daily Driver:
CookieBoy,
     Rule of thumb. Install the overflow tank...make sure the tube goes to within a 1/4 inch of the bottom...fill the tank to 1/3 rd...mark that level with magic marker...fill the radiator to top put cap on...drive car for 1/2 hour and let cool over night...check level the next day( the fluid should be gone or lower because of compensation to cooling system for air comming out)...fill again to level if needed or leave alone if at level.
The overflow tank also enables you to run distilled water in your cooling system without buying more all the time...those minerals in tap water do collect around the openings of the rad. channel and render a radiator useless in from three to five years.
Also, the overflow tank will let you know if you have a pressure leak because the level will go down due to the replenishment of coolant to the cooling system.
Remember in Tulsa how I was splitting my bottled water with ThunderPinto all the time.
Quote from: 77turbopinto on September 11, 2007, 09:15:53 PM
I plan to put them on my cars (soon) to CATCH coolant; leave it empty, but have the can there to catch the occasional burp so it it does not harm the environment or motorcyclists.
I hadn't thought of that... worth considering and I like your reasoning...
High Horse, you have some good points there...
CookieBoy, The radiator will drip to a certain extent because it is supposed to if the pressure in the cooling system is exceeding your 13 pound radiator cap. The reason that they started putting tanks on cars it to keep the anti-freeze drip off from killing the earth. When you shut the car off and the cooling systen cools down then the collected coolant is sucked back into the engine because of contraction. Just because your car did not come with a coolant bottle does not mean it would not be good to put one on. It would save you dough on coolant and rid your ride of that unwanted air in thesystem. which does nothing to cool the engine.
Tigger01, If your car overheated then your themostat is junk and should be replaced. Thermostats will retemper to whatever higher cooling system fluid temp. that they are forced to be exposed to....for whatever reason. People often fix the problem and then assume the therm stat is still ok....well it is not.
Cookieboy,
I agree that they are not "needed" for proper operation of the car.  I plan to put them on my cars (soon) to CATCH coolant; leave it empty, but have the can there to catch the occasional burp so it it does not harm the environment or motorcyclists.
Hey Douglass, I did add an overflow tank but removed it shortly after installing it.... let's see if I can explain why I found it to cause a new problem that I didn't like, provided no benefit and was a waste of time...
Let's start here.... I got the overflow tank from the 1980 Pinto I scrapped, I had never personally recalled seeing an overflow on any of my previous Pinto's so I was puzzled and decided to keep and try it out. Got it installed and worked as expected... kind of...
Next... my understanding of an overflow tank is that when extra antifreeze needs to escape from the radiator due to normal heat caused by running the car it then has someplace to go instead of the ground... Once the car cooled down the tube going into the overflow would allow the extra antifreeze to be sucked back into the radiator and I would always have a full radiator... sounds good right???
Now here's the problem I didn't like... the Pinto always smelled like hot antifreeze whenever I would drive it to full operating temp. The steaming hot antifreeze would escape from the radiator and go into the overflow as expected and I could smell it while driving or just standing next to the car. I didn't like that. That's why I removed it and have no desire to install one again.
Also to consider... none of my current or past Pinto's had overflow tanks that I recall, fluid in the radiator was always the same... just a bit above the coils and nothing would leak out and the cars never had overheating issues. Worse case scenario I had with my car and potential overheating was... I was in the local parade with the 73 on a hot sunny day with it doing nothing more than idle for almost 30 minutes without it overheating. I did vapor lock in the carburetor but my temp stayed at acceptable levels and I firmly believe I didn't overheat. I was able to get the car started again by removing the fuel lines, tapping on the carb and working the throttle back and forth... car was still hot when I got it running again... and it started right up and ran well.
I may be wrong but I would suggest Ford knew what they were doing when they didn't put overflow tanks on most Pinto's as they really aren't required. I only say most because I have seen 1 that did, but who's to say someone didn't add it somewhere along the line.
Please keep in mind this is just my opinion based on my experience... Not! rule of law according to cookieboy  ;)
Tip for Cookieboy:  Get an overflow tank.  To keep that from happening again, plus giving your coolant system more capacity making it essentially larger.  On my 79, we got a universal unit from Checker (same as Schucks and Kragen) Auto Parts.  You could even be sneaky and put it under the fender behind the headlight.
For Trigger01:  All the suggestions so far are good, I dont suppose that when the timing belt was replaced that you replaced the water pump and thermostat as well?  Just a thought.  I know it's a bit late now, but I recommend doing so to anyone I know.  I mean if you're going to have the front of the motor torn down that far anyway, might as well.
Another thing, try getting the car hot when it is setting there and see where it is leaking.  An easy way to do this is to cover the grille opening with a towel or blanket to keep air from passing over the radiator fins.  BE VERY CAREFUL NOT TO GET IT INTO THE ENGINE BAY.  This will make it heat up fairly quickly, helping you locate the source of the offending steam source.  We want you to be safe and enjoy your car.  Also, make sure you don't make a bad situation worse.  If it really is overheating, obviously you don't want to hurt your Pinto.
Good luck to you!
--Doug
Bill and Crazyhorse both offer good suggestions... but here is something that happened to me w/my 1980 pinto....
first off car overheated and blew the headgastet so I fixed the head gasket and the leaking radiator that caused the problem was swapped out. Radiator fluid was filled up "to the top" and lots of little trips to see if all was good... and all seemed fine until...
I took that first long drive... and steam kept coming out from under the hood... the answer was simple... I filled the radiator "to full" and the extra would come out the overflow and leak down the side of the radiator, fan would "suckup" the anti-freeze and spray it all over the hot engine and cause the steam effect...
I find w/my pinto's anyhow that just enough anti-freeze to cover the tops of the coils (for lack of a better/correct word) as you look down into the radiator is normal. If you fill the radiator to just below the fill hole... the extra leaks out and could cause the steam...
I had forgotten about overfilling Pinto radiators since I hadn't had one in 10 years or so but that experience reminded me quick.
Might also want to check hoses and clamps... since you didn't mention the engine light coming on to indicate over heating (I know they're idiot lights and shouldn't be trusted but...) might also be as simple as a clamp not tight enough and leaking once it gets hot and leaking on say... the exhaust... right below the heater core lines... since you did do timing belt, fuel pump and oil leak fixed before the problem started it might be worth checking anything you disconnected to get at the parts replaced or fixed...
not sure if any of that would help but might be worth checking... doesn't cost anything but time to look.
12mi is about how long it'd take for a stuck thermostat to overheat a car. Unfortunately it's also how long a bad waterpump takes.
Personally I'd start with the T-stat. You know simple/cheap things first.
Trigger01
First off; What EXACTLY is it doing?
Steam coming out of the engine bay.
Is it literally boiling over, or does the light come on or the gauge read high?
It did on Saturday, and I let it cool down and added a little water to refill.
Have you done any maintenance to the car lately?
Car hasn't had any maint. in the last 2 1/2 weeks. Before that Timing belt replace fuel pump and oil leak fixed
Have you made ANY changes to the car?
New Radiator cap.
Have you checked the coolant level?
Yes, it's ok.
Do you have coolant in the oil?
haven't checkedIs there steam coming out the exhaust?
Not that I noticed
Is there a "milkshake" looking goop in the valvecover?
Don't think so.
How does the fanbelt look?
Good. I think it's new too.
Has this been a problem that has been going on for a while, or more acute in nature?
Since Saturday. Only noticed it 2x, on trips over 12 miles.
Have you tried to fix this issue, and if so, what did you do ans what was the result?
New radiator cap and didn't fix it, thought it might have something to do with the pressure...
-Mike
SOLD
1978 Pinto Runabout
Daily Driver:
Quote from: Trigger01 on September 10, 2007, 08:04:38 PM
My car is over heating. What do I need to check and any ideas how I can fix it? I don't reall have the money to take it to a repair shop.
Thanks,
      ~Mike
Have you tried to fix this issue, and if so, what did you do and what was the result?
Trigger01
Thanks,
      ~Mike
-Mike
SOLD
1978 Pinto Runabout
Daily Driver:
