Date: 07/10/2016 10:17 am
Date: 02/28/2018 09:33 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 08/22/2018 09:23 am
Date: 08/02/2019 04:18 pm
Bumpers
Date: 07/06/2018 04:47 pm
Date: 10/28/2018 08:45 am
Seeking parts
Date: 10/18/2020 10:35 am
  • Online today: 802
  • Guests: 163
  • Total: 163
Help car won't start ??
Started by dangerusdug, September 05, 2007, 11:36:29 AM
dangerusdug
CAR is FIXED !!! End of transmission. :fastcar:
dangerusdug
New question, now that I have everything back together any idea where to set the timing back to ? Back ground; engine is bored 40 over, has a mild crane cam with a Holley 390 4bbl. Thanks D.D.
dangerusdug
Howdy, thanks for the help, we got her running. After replacing every electrical part ! It turned out to be the tach grounding out. So no more tach. Thanks again you guys are alway there to help  ;D Thanks D.D.
On the older cars I ALWAYS check the fusable link at the starter relay.
Frank
Is the camshaft turning? If not, and ther is NO spark, the timing belt is most likely at fault. If the cam is turning, I would pull the + wire off the coil and run a jumper to the battery.
dangerusdug
Howdy all, 79 Bobcat (2.3, 4spd.). Car won't start it turns over but NO spark. Replaced ignition switch,cap,rotor, plugs, plug wires,coil, brain box, pickup coil,any ideas ? Must get car ready for storage. Thanks D.D. ???
