Date: 01/28/2021 03:49 pm
Date: 07/08/2022 11:51 pm
Date: 01/18/2017 05:35 pm
Date: 01/20/2018 07:51 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Date: 09/15/2019 12:38 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 06/25/2021 12:59 am
Date: 04/30/2023 04:31 pm
  • Online today: 1,044
  • Guests: 104
  • Total: 104
Exhaust pipe from ground distance
Started by dave1987, September 05, 2007, 03:33:32 AM
So I was pulling the last few bits and pieces I though I might need off of a 74 wagon at the salvage yard today and I looked at the mounts for the exhaust pipe. It has a 2.3 in it just like my Sedan, but it has a bracket that is bolted to the engine where the starter cable guide is bolted to. The bracket is basically just a rounded piece of metal that conforms to one side of the pipe, and then a U-bolt that clamps around the pipe and is then secured to the engine block by a single bolt. Is this how it comes stock from the factory and could it be the reason my pipe hangs so close to the ground?
It is factory. I was told by my dad that he hammered out the inside of the catalytic converter because it was causing the engine to misfire. I don't know if he had to drop the whole pipe to get the unit down though.
Is your exhaust factory stock or has it been replaced at one point?
Is the exhaust pipe and the catalytic converter supposed to hang lower than the undercarriage on a 78 Sedan? I've noticed my pipe will bottom out when going over speed bumps sometimes. From the lowest part of the pipe to the lowest part of the undercarriage, it's about 4 inches. Is there something wrong here??
