Rear Bumper
Date: 07/26/2021 01:08 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 04/14/2023 06:15 am
Date: 09/15/2019 12:38 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 01/24/2021 07:54 pm
free transmissions
Date: 11/28/2019 10:21 am
  • Online today: 376
  • Guests: 393
  • Total: 393
Getting Started On A Rolling Restoration
Started by ponyexpress, May 23, 2004, 07:07:03 AM
Poison Pinto
If you want it drivable, your priorities should be 1, 5, 2, and then 3 and 4 in whichever order you wish.
Now, for your questions:
1) Don't know without looking at it.
2) No, not difficult at all. As Straw Boss says, you're simply rerouting the wires from the side lights to splice into the wiring for the front/rear turn signals.
3a) and 3b) Read through some posts on this site. Also, look at the May 2004 Hot Rod, pp. 105-107. There's a description of swapping an '84 Mustang to 5-lug patterns with larger disk brakes on all 4 corners. While the part numbers may not be accurate for your application, reading about what's involved may help you make decisions...especially since you mention your lack of mechanical knowledge and tools.
4) I own a wagon and don't know the specs on runabouts and hatchbacks. What I do know is that if you go to a salvage yard they can tell you if the swap works. They have computer programs that let them what parts are interchangeable. Also, if you develop a good reporte with knowledgeable clerks at your local auto parts store, they can often tell you if a swap works. Remember, both places make their money by selling you the replacement parts. It's in their best interest to give you the info so that they can make a sale and keep you as a happy, repeat customer. You just have to go about it in a "you-scratch-my-back-and-I'll-scratch-yours" manner because a lot of times they'll just say "I don't know" if they don't see any profit in giving you the answer. I've found that by becoming a regular customer at the parts store I'm more apt to get a straight answer from the clerk. Yeah, I pay a few pennies more for a quart of oil over the big box discount stores, but it's worth it. If you mention the word "Pinto" to the average Wal-Mart auto "specialist," you'll get a blank stare followed by "Aren't those the cars that blow up?" It also helps that I dropped $225 on an engine hoist from the parts store. Now, the moment I walk in the door, I have a clerk right there asking how they can help me. And they're more than happy to discuss my car needs with me...even if all I'm walking out the door with is a couple quarts of oil. This is also a great way to get help with your brake swap info.
5) Are you going to redo the vinyl or go with the "hard" look? It'll look ugly under the vinyl when you rip it off. Most cars I've seen with the half-vinyl removed have a distinct difference in paint quality. Plus, you wind up with the edge trim just sitting there. If it's been loose for a while, you may discover some heavy-duty rust spots from pooling water that have been conceiled by the vinyl and the head-liner.
6) Yes, no, and half the time you will be driven there.
On my '74 runabout the side markers flash with the turn signals. If yours don't I'm pretty sure Straw Boss' suggestion will work. as for 5lug conversions they've been done by several people on here. as far as I know the best fit is the rare '57-'59 ford wagon rearend. these being fairly standard 9" rears you should find disk brake conversions pretty easily. i'm thinking that maybe the check valve in your fuel pump may not be working. This will allow the fuel to run back out of the carb. This means that it always acts like it's out of gas 'till you start it up. (hence the need for ether.  If you put some gas in a windex bottle it will do the same thing without being so hard on the motor.)
straw boss
1.  That sounds like the choke is not working properly.  Check to make sure the linkages are clean and work freely.
2.   I guess it depends on what you want.  Do you only want them to blink with the turn signals, or do you still want them to function as side marker lights, and blink as well?  Maybe you could accomplish this by running the side marker ground wire to the turn signal wire.
Just a thought, I haven't done this myself.
3-5.  Don't know
6.  No doubt, but so is everybody else who still drives Pintos!  ;)
ponyexpress
First off, just so you know, I am not very mechanically knowledgable, I don't have a lot of specialized tools, and I live in an apartment, so I can't do a whole lot of major work on my car there.
That said, I have a 78 Runabout, 2.8 liter, automatic, that I am trying to make road-worthy again.
It's been sitting for a couple of years, started only occasionally. It will start, with with the help of some starter fluid sprayed in the carb. And it will drive okay, it seems.
So, here are my priorities:
1. get it to start easily without using the ether. I have replaced the plugs, plug wires, distributor rotor and cap, and the battery. When I do get it started, it runs just fine. The problem is getting it started.
2. replacing the side marker light pigtails. Some idiot cut them all off.
3. replace all of the weather-stripping, window channels, fuzzies, etc.
4. replace and/or repair the front seats, seat belts, dash pad, and carpeting.
5. complete brake job.
Those will get the car on the road again, I hope.
So, my questions are:
1. do I need to replace the fuel pump? Since once the car is started, it seems to run okay, is that necessary? I plan to replace all of the vacum lines today, so will that help?
2. I'd like to replace the side marker lights with the kind that blink when the turn signal is on. Is that very difficult to do?
3. I'd like to convert the brakes to larger, more effective four-wheel discs. Any suggestions?
3. I'd also like to go to a 5-bolt pattern, because I want to put some American Torque Thrust D wheels on the car. Again, any suggestions?
4. My car has the all-glass hatch, which I hate with a passion. Can it be replaced with a small window hatch, maybe from a different year, without having to do a lot of modification work?
5. It has a half-vinyl roof that is loose and wrinkled that I want to remove, but I need to know what to expect, and what I will have to do after removing it. I plan on having the car re-painted, but it will be at least a year before I do.
6. Am I out of my mind? ;D
Thanks for your help.
