Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 12/15/2018 02:21 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 12/31/2017 09:03 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 05/22/2018 01:54 pm
Date: 04/27/2018 10:28 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
  • Online today: 656
  • Guests: 526
  • Total: 526
73 Pinto leaking in front footwells
Started by Whoosh, August 06, 2007, 03:44:15 AM
Whoosh
thanks guys, my pinto isnt that rusty & is in pretty good nick, it is showing some signs around boot (trunk) lid & doors but generally shes sound. it leaks more on the drivers side & seems worse when sitting rather than moving. Seeing as Pintos are uncommon in New Zealand most people compare them to English or Aussie Cortinas which had the same 'blocked vents causing water traps & cancer' in the same area.
turbowagonman
I had a leak on my 80 Wagon into the Drivers side footwell. My problem was (unfortunately I didn't take any pics before I scrapped the car) the Drain hole in the Cowl was plugged from sitting outside under a Tree and then the Cancer just got worse and worse, it was so bad that if I was driving the car in the rain and had Sandals on, my feet got wet! I didn't realize WHERE it was leaking from until I pulled the dash and wiper motor.  :(
Well the car is it's final resting place R.I.P., it was a great car and learning experience.
turbowagonman
UltimatePinto
Here's where mine leaked. As you may see, I need to add some bondo or silicone to finish the job.
Most likely best addressed from the top but you would have to cut the topside sheetmetal to get to it than weld afterwards.
This on a 72 Runabout that sat for a long time outside next to Long Island Sound.
Al
I have read on this forum that people have had leak problems with the windshield gasket and body seams.  The leak problem I have had on several Pintos has been with the vent stand pipe located inside the cowl rusting through (usually gets the passenger side floor wet).
Hello Whoosh,
:welcome:to the PCCA.
How rusty is your 1973 Pinto??
Will your 1973 Pinto leak while sitting or only when moving??
Whoosh
Ive run silicon around windscreen but it hasnt made much diff, tried putting tape over the cowl vents & that slowed it a fair bit but still got in somehow. What is the common problem?, how to fix? & approx how much??
