1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
oldskool787
Date: 02/12/2017 12:42 pm
windshield
Date: 04/14/2018 08:53 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 08/17/2022 06:27 pm
Date: 05/13/2021 05:33 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
  • Online today: 802
  • Guests: 287
  • Total: 287
Leaking from my distributor (73 2.0 engine) Anyone know what size seal this is?
Started by FESPERMAN, July 25, 2007, 04:44:24 PM
FESPERMAN
I cleaned it real well and drove it to work this morning.  I think it is only the fuel pump.  I will go get a seal from Schucks and swap it out.
Hello FESPERMAN,
Your leak could be both the dist and the fuel Pump.
Do 1 at a time and keep us posted on what U find.
FESPERMAN
FESPERMAN
I went back out and looked and cannot see much of a leak.  I cleaned the engine for the first time today.  There was no leaks after running for awhile.  I will see how it runs tommorow.  Maybe it will like being clean and run better.
It is running a little rough.  I still need to change the oil and motor mounts this weekemd.  I am sure that old gas is probably a problem too. I may nbeed a carb rebuild.
Hello FESPERMAN,
R U sure it is not the fuel pump gasket?
I will check to see if the O-ring has a part number.
FESPERMAN
