Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 06/12/2018 08:18 pm
Date: 08/16/2018 08:54 am
2.3 carb intake
Date: 07/15/2020 09:25 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 12/24/2016 04:13 pm
  • Online today: 128
  • Guests: 97
  • Total: 97
This is how i spent my weekend.  Since i was not in a position to do any mechanical work on it I decided to clean up the engine compartment.  I have always hated the chrome valve cleaner.
and
yeah i know the air cleaner lid is too big, what I need is a 6 " air cleaner top.  Anybody got one?????????????????????
Chris,
This is what i would do if I was in your place.  A totally sealed and vented metal battery box.  I would put it in the right rear corner in the back.  I have added a main shut off switch on mine but it doesn't appear to have room in this box.  If you want to go in that direction let me know and we can talk about it.
You can buy them cheaper but not better.  This is no place to scrimp.
http://www.jegs.com/i/Taylor/895/48100/10002/-1
Quote from: hellfirejim on July 31, 2008, 06:21:20 AM
Let me check some things and I will get back to you.  BTW: Do you plan to take it to the track???  This will make a difference.
Jim:
  NO track for me....
1) I have never raced
2) I don't want to build a racer
3) I'm chicken  ;)
No, seriously, building as a driver, nothing overly powered or modified, just a nice, clean example with tasteful mods.
Quote from: Pintony on July 30, 2008, 11:39:19 PM
Hello hellfirejim,
I must admit that I have never looked at this thread???
Not sure why???
The Shur'tug'al thing totally threw me off!!!!
Now that I have looked, I'll go back to the beginning and read all the posts...
I give you a 1-UP for your effort and for your garage post about "NOT GIVING UP" on your project.
Welcome to the thread.  Shur'tug'al is a word from an ancient language that means Dragon Rider.  This is in reference to my adding turbos to the mix when I get the car to where I want it.
I am truley amazed at all the views of my little car.  I am so far from where I want to be with it but at the same time I have come a really long way so for that I am greatful.  If life would stop getting in the way I would be further along... Oh well ;D
Quote from: popbumper on July 30, 2008, 09:14:20 PM
HI Jim:
  Sorry, should have said my car is a wagon (1976 model). If you can make a suggestion, please do.
HI Jim:
chris:
Go ahead and start your own project thread.  you will be glad you did so.  Beside it will give me an opportunity to check out your progress.
I don't remember what type of Pinto you have but it does cause you to be careful on the kit that you buy.  If it is a sedan then a batterry kit from Summit or Jegs will probably work.  Make sure it is totally sealed and has a vent to the out side.  Or is at least adaptable to do so as you have to vent it outside the box and trunk area.
If it is a fast back and you want to go to the track  then you have to isolate it from the pass compartment by some sheet metal,  However if you are like me and I figure i probably wont ever make it to thetrack then put it where ever you want.
To answer your question the only part of mine that is commercially available is the box, all else is custom made.
Jim:
  I have had a few threads started, most of mine is under the title "Rust loves to hide" in the general section. I suppose like the rest of you I need to move my project to a thread here.
HEY - where did you get the battery box? Is it all self-fabricated? Are there "kits" available for doing this (relocating the battery)? I would like to do the same.
My goal of doing this was to share what I have learned and show it can be done without fancy stuff.  I have spent my whole life doing things this way so naturally i just jumped in and did it.
Chris, if I haven't missed it start your own project thread.  It keeps me going to do something even very small each weekend that I can.
I am honored by how many views there are on this little project pinto... I hope people can learn at least one thing from it.
Well Jim, I gotta say, this is the first time I have read through your thread in entirety. Impressive! Certainly you are an ambitious man, and congratulations on all you have done. You have taught me several things:
1) Perseverance is a good thing
2) (I need to) quit complaining about not having a work space and just DO it
3) (I need to) remember that I too am blessed every day.
Thanks for your insights, thoughts and prayers with you.
I have not gotten the brakes done yet as it appears it is just one of those things that will get done when it gets done.  Something more important and something I want to pass along.
Do NOT use regular teflon tape when taping fuel connetions.  Gas will eventually eat the teflon tape.  The is a special pink color teflon tape that is specifically for gas lines and such.
Got a good start on the air cleaner but don't expect much as this is just temporary until I get the fuel injection installed.
It was a pretty good weekend as i got some stuff done between the rain showers.  The first is the phenolic spacer.  If you remember I had an open 1/2 spacer which was ok but not what i really needed. So i got the 4 hole spacer and modified it to work.. there's that word again.... :read:
The next thing I did was install a Hurst t-handle with a button for the line lock and wired it in.  To work it requires you to manually flip the toggle switch and then press the button.  the toggle switch is to protect me from myself... :lol:  One shot is of the shifter itself and the other is how it fits in the interior.  personally I like it which is good because it is my car.
and
So what's next???  Well if things go right I will get the brakes done during the week, I hope and then next weekend I plan on making the carb air cleaner.  I will also tell you about the fuel pressure gauge.
This second post is going to be a little different.  There have been over 3000 views of my project over the last couple of years.  The people viewing may think that I have a big garage and a machine shop to get all this done.  Well here is a picture of my garage:
and here are a couple of pictures of my machine shop:
and
The point of this is NOT sympathy for me but to point out that you don't need all the fancy stuff to get your Pinto the way you want it.  People just starting out and people who are burned out on their projects take heart, it can be done.  It just takes creative thinking and determination.  Take your projects and break them down into singular projects and tackle one at a time and before you know it it is where you want it to be,  I still have two more steps before my Pinto is drivable,  exhaust and brakes.  But i couldn't be happer with the results because I built it my way and the best that I can do with what I have to work with.  I am very glad I have the car as it helps keep me sane of course if you own a Pinto that part is questioned anyway. :lol:
So keep on working on your project and soon enough it will get done.
I am going to post twice tonight.  This one and one more.
this post is about finishing the batttery box w/cutoff switch.  The pictures tell apretty good story.  i just simply finished the wiring and closed it up.  It works just fine.
When you look at the pictures of the battery box remember that the only  stock part is the lower plastic bottom.  Everything else in the picture is custom made in my shop.
I will post two pictures and the links for two more if you are interested.
here are the links for the other two pictures.
http://i93.photobucket.com/albums/l66/hellfirejim/battery%20box/cutoffswitch07-12004.jpg
http://i93.photobucket.com/albums/l66/hellfirejim/battery%20box/cutoffswitch07-12005.jpg
Now on to the second post................
I am going to try this again. the last time the site just freaked out on me.
Been busy today. I am mounting my master cutoff switch to the side of the battery
box so only the switch handle will be visable.  When i turn off the car i can reach
back and flip the switch to isolate the battery from the car.
Since the battery box is plastic i felt it neccessary to make up mounting plates
both inside and out to support the mass of the switch.  It is amazing that small
parts such as these take as much time as the big parts.  I had to design the shape
of the plates, then drill a hole where i think the switch will poke through. I put
a punch through the hole to keep the two plates centered and one at a time drilled
the connecting mounting bolt hole in each of the 4 corners.  The challenge was to
keep it all aligned.  After opening up the center hole to allow the switch to pokethrough
I then clamped onto the battery box and started the drilling and mounting of the
plate all over again.  Because the box was not a flat piece i also had to make spacers
to keep the mounting plates flate.  With the mounting plates secure I then cut out
the hole in the center using the plates as a guide.  Did I mention I LOVE uni-bits??????
So now we are to the point in the pictures. The outer plate is painted black and
the plate where the cables go into the box is also painted black....  now that I
am thinking about it I might just paint the outside of the switch and handle black
as to maintain the stealth look.    No wonder I am tired.  I also made multiple
trips to the hardware store to gets the necessary bolts.  why is it that you might
have the bolt but it is the wrong length?????
Tomorrow, I am going to finish the install of the switch and the cable entry plate.
Wire it all up and see if it works.  Depending on what happens and how long it
will take I might startup on mounting the muffler.
Brakes get done next week if the wiring goes well.  The goal is to get it on the
street drivable before surgury.  Now that would be good medicene.
Part 2:
I then placed the carb on on the manifold and realized that I need to get 1/2 " of height to make it all work.  So I first went and got longer carb studs. Then i went looking for a 1/2" carb spacer.  Nope ain't going o happen so i then remembered the guy i bought the Pinto from had a shelf full of ..stuff.  Iswung by there and got a free 2" spacer that he didn't need.  Well lo and behold  each end had a 1/2" flat plate cast to a 1" spacer to get 2".  I simply cut off the plate and with the longer studes bolted it in.
It is an open spacer and i really need a 4 hole 1/2" spacer to make it right.  Anyway i fired it up and happy days.  it ran but wasn't "right".  Sunday i raised the fuel pressure from 4 to 6 lbs.  i then took it down off the jackstand  after 2 years and set it on the ground.  I hit the key and it fired like it was fuel injection.  I ended up driving it for a 2 block trip but straight pipes and dragging rear brakes created an issue.  I did learn something though and that is i am fooling myself to think I can manually operate a switch for an electric fan.  i am going to get a temp controller unit.
So that's about it for now.  if you have any questions please ask.
Thanks for the good words and i am truly humbled by 2900 reads of my little car....  ;D
I am going to try and explain what i did to get the carb, manifold and linkage to all work together.  if it gets too long I will stop and I will do another post.
Ok first is the manifold.  stock it is an offy 360 that I have modifed the plenium area.  Next is the holley carb and it is a 450cfm that was gone through by a friend Walt Bainey out of Ohio and he did an excellent job.  I ended up using a stock accel cable holder but modified. That word seems to come up a lot.
The carb is mounted backwords so the linkage is facing the fire wall.  The linkage post is at the bottom of the linkage and yes it does open all the way.
Mounting the accel cable holder i first had to make a plate to move the holder to the right about 1 1/2" just used a flat plate.  I also used button head bolts to hold the plate to the manifold for clearance.  With the cable popped on that carb I set the cable holder down and realized the angle was way off.   So i did the first thing that came to mind and grabed the whizzer and made two cuts so I could bend the piece flatter to improve the angle.  Don't know what angle it ended up at but it works.  I took the piece over to the guy who does my welding and he cut two fill pieces and tigged it for $7.  i gave him $10.
looks to be agood place to split the post.  be back in a minute. here are the pictures to compare to what I have written.
http://s93.photobucket.com/albums/l66/hellfirejim/Its%20ALIVE/
Jinxter
Almost 2900 reads...!!  Your perserverance is a testament to the dedication of Pinto enthusiasts everywhere.  Great job - can't wait to see the turbo version!
Beat it to fit, paint it to match...
Today is a very good day.  The Pinto came down off the jack stands and i drove it.  Not real far as straight pipes and draggging rear brakes discourage this.  neverthe less it was great and a good payoff for the two years i have been working on this.
Here are the "beauty' shots.  http://s93.photobucket.com/albums/l66/hellfirejim/Running%20Free/
Today is an important day.  Today it is alive for real!!!!!  This is with the new coil and new intake manifold and  new carb.  i fired it today and my, my, my.....  It was responsive.  In the sense of fairness it does have a few issues but I can fix that.  it idled clean and responded very well.
There is a whole lot to the story so it will take a number post to fit it all in...
Here is a teaser.
PS: I know the carb looks huge but it is only 450cfm and is progressive.
Glad to see you hanging in there and getting some progress. I hope you can make a full recovery. Best wishes...
Yesterday was a good day.  Between dodging rain showers I managed to first get the oil and filter changed.  That oil filter sure is easy to get at with no intake manifold. :amazed:   :lol:
Most importantly I got the intake manifold installed and plumbed.  Here is a picture:
I am hoping that with the three day weekend coming up I can get it running....
I also wanted to express my amazment that almost 2700 views of my project, I am humbled.
today, sat, is a good news day.  I was out working on the car and just came in before a big storm hit... :lol:
First thing I did was clean up the mess and tools from all the wiring work.  What a mess.  Then I painted my new claipers and NO I didn't pain them red.... :nocool:
i finished porting the intake manifold and took it over to my buddies to bead blast it.  Came out a funky aluminum color but with faint blue stripes.  hard to describe, I will get pictures tomorrow.  Speaking of tomorrow i start with an oil and filter change and then I actually start puting things back together.  It is posible that by the July 4th weekend this may be running.... we shall see.  it would be really cool to have this running before the surgury....
Well I have finished the wiring on the car and i thought I would be happier...  This Scot K death thing has hit me pretty hard.  As a racer I understand why he does it but if you have never raced at that level, you simply cannot comprehend the height of the dangers involved....  Only by the grace of God have there only been a few. :'(
maybe some pictures if anybody wants to see the finished work.
I am down to finish wiring the gauges for dash light power. [see question in help section]  That plus a ground and the gauge part is done.  Then I get to the fun stuff, the intake.  I get to finish modifying it and get it installed.
bobscat
Hey Jim, thanks for the heads up, and glad to see you are up and around fiddling with the car!
This is more of a heads up from my experience.  I had a sunpro mechanical oil pressure gauge and i decided that if that feed line for the car was coming inside I did not want plastic or copper. I found a braided hose at a decent price.  I went to connect it to the gauge after running it through the firewall and found it would not fit the gauge.  It seems that gauge only had compression threads on it and there was no adapter available.  So I bit the bullet and bought a VDO gauge.
On another board I read of a number of people that have had problems with this sunpro gauge leaking or filling up with oil,  I was spared on shear blind luck which is ok and appreciated.  The real deal here is don't short cut on things like gauges and such as it will come back and bite you in the butt.
Amazing enough I actually got to go outside and work somemore on the Pinto.
Here is a picture of what the wiring looked like:
and
this is what it looks like now.
and
Just one more thing done.
Thanks for the kind words.
It was so perfect outside roday that I had to go work on the car. I installed the oil and water sending units through the firewall.
In the oil sending unit the top plug will be for the oil pressure cut off for my electric fuel pump.
Not a lot of work as i had to stop and rest a lot but it is one less thing to do.
Our thoughts and prayers are with you fellow Pinto lover!  :)
