79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 10/28/2018 08:45 am
Automatic transmission
Date: 02/13/2021 02:52 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 04/30/2023 04:31 pm
80 pinto original
Date: 08/04/2019 10:45 am
Date: 03/06/2017 01:19 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
  • Total Topics: 16,268
  • Online today: 161
  • Guests: 91
  • Total: 91
anybody speak T-5?
Started by dholvrsn, July 14, 2007, 01:37:40 PM
I had the stock shifer on mine, slightly modifed to use the stock Pinto boot, but it's angle was too far forward for me, and it was a little too tall for the boot. I had to pull the tranny back out for a different reason so while I had it out I modified the shifter to lower it and pull it back. I like it much better, but if I need to remove the carpet again I will bring it back just a little more.
turbowagonman
Quote from: dholvrsn on July 14, 2007, 02:14:04 PM
How much do you want for them?
I've only got the one set that is on my car, but I'll take a look around and see if I can scare up a set for you.
turbowagonman
turbowagonman
Quote from: dholvrsn on July 14, 2007, 01:37:40 PM
Also may need a shift lever and knob in the near future.....
Thanks!
I used a Shifter Lever & Handle out of an 87 TC. It's also the same a Mustang. It worked just fine.
turbowagonman
I just got a T-5 transmission for a 2.3 Ford. I'm trying to figure out the specs, especially the OD ratio. The tag reads:
(inverted delta) E7ZR - 7003 - AA        REP  AP
L3 - 52 - 162       38237     D2073
How hard is it to replace the input shaft without some pesky needle bearings and their ilk scattering all over the place?
Thanks!
