Date: 08/16/2018 08:54 am
Date: 07/11/2023 11:39 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 09/06/2020 01:57 am
  • Online today: 403
  • Guests: 159
  • Total: 159
'74 Wagon Project (Now with link to photos)
Started by Poison Pinto, April 29, 2004, 10:57:13 PM
if they are giving you this much grief....i'd just cut them! Cutting metal with fire always make you feel more manly! ;D
Poison Pinto
DAY 5 (May 20) Well, I gave the threads another soaking over night (this would make the 3rd night's worth), and hit them with the propane torch...yet again (even though I've repeatedly tried heating/soaking, I still want to thank Boss for the suggestions). No luck.  >:( This is what gets me: I work on an oil well service rig. I'm used to dealing with big honking bolts that are rusted from years of exposure (and neglect). I'm used to spraying penetrating oil on the threads and I know all about heating up the threads with a torch (or a hammer). So why I nearly pull the car off its jack stands and can't get a single bolt to give confounds me. I'm beginning to wonder if there isn't something else I need to do first. I've never had this much problem with a rear end before.
Anyway, I dropped the rear spring brackets and shocks on both sides. Now all that's left is the front mounts on the springs. :-\ Guess I'll wind up replacing the springs along with the axle.
Just for good measure, I pulled the roof rack. At least I have some feeling of accomplishment for the day.  ::)
straw boss
Soak the threads with penetrating oil and let them sit overnight.  It may help to put some heat on the nut with a propane torch before you start to loosen them.
Poison Pinto
DAY 4 (May 19): After much poor weather and late hours at work, I get a chance to work on the wagon again. Decide to pull the rear end. Unfortunately, the U-bolts that hold the axle to the springs are bolted on too tight for anything I've got. A good dose of WD-40, followed by a drenching in PB Blaster and still not one will budge. I pulled out the 1/2" breakover drive with a cheater pipe. Nada. So I unbolted the rear spring bracket and pulled the shock on the driver's side. Got to the front spring mount and that bolt didn't budge.  :-\
Anybody have a suggestion what I can do to drop the axle? I'm about ready to just cut through the U-bolts.  >:(
Poison Pinto
I'm planning on using an M-II 8" rear just for the ease of installation. Thanks for the info on that. I want to use the car as a "daily driver" to and from work (about 30 highway miles one-way). I also want to do some local cruising because this car is intended to be seen (and heard).
DAY 3 (May 14, 2004): Again, because my employer seems to believe that if the sun's up, I should be working for him, I didn't have a lot of time before dark. Still, I easily pulled the seats and factory shag(!) carpet out of the interior.
The headliner is nearly 100% (only a 1/2" tear near the edge over the back seat), so that will stay. The door panels and other interior plastic pieces are also in serviceable condition. Because of this, I'll paint the exposed metal parts of the interior black and the rest will remain its original green. The original car color was T4 (I call it "pea green"). I plan on painting the exterior chartreuse green (the color of the monitor screen icon or IM scroll icon when you're online). I'm hoping it doesn't clash!  :P
yes the 8 inch is a stout piece when set up correctly (my buddy tom has run 11's with his 351w and a 4:11 geared 8 inch) the 8.8 should fit, its 1/2 inch wider on each side that the 8 inch, but it was meant for coil springs and a totaly different mounting arrangemeant. You would have to cut off the coil perches and mounting flanges and add on some leaf perches in the proper area. Gears.....depends on what tranny your running and what you wanna be able to do with the car (highway driving, racing, local cruising) if you go with a T5  5 speed you can go with a 4:11 and still be able to cruise out on the highway with ease!
Poison Pinto
Will an 8" M-II be able to handle the torque (I'd think it should, it's only a 302, but what do I know)? Conversely, will an 8.8" bolt into my wagon without chassis mods?
And another question: since I don't plan on racing with the vehicle, would it be better to go with 3.55 or 3.73 rear end ratio? I want to go faster than the local authorities deem proper, but I don't need to go as steep as 4.10 or 4.11.
8 inch rear out of a mustang II  ('74 to '78)  5 liter mustangs have 7.5 in earlier '79 to '85 ish later ones '86 to current have 8.8  they are a completely different animal! ;D
Poison Pinto
Okay. A T5 tranny and 8" rear end from a 5.0L Mustang (Makes note on "To Buy" list).
Side note: the current engine is a 2.3/140 cid.
DAY 2 (May 12, 2004): Only a couple hours between work and dark. Pulled the hood, grill, and both front fenders. (My goodness, how many of those blasted bolts do they need?) One thing's for sure, the car may blow sky high but the front fenders aren't going anywhere!
Next on the "to do" list is to pull the seats and strip the interior. I'm planning to redo the interior in black and reskin the front seats in leather (have I mentioned I have millions to spend on this project? ::)). The back seats aren't going back in...the wells in the floor pan back there look like they'd be a good place to set a couple 18" or 24" subwoofers.... 8)
sounds like entertainment!  C5 tranny is an automatic, a decendant of the C4. For a 302 you want a T5 standard tranny from a 5 liter mustang, make sure its from a 5 liter when you find one!
Poison Pinto
Finally.... It's been about a month since I bought my '75 Pinto wagon and today I had the time and assistance to get the vehicle towed home.
I took all sorts of pictures and will post them on the board here in a few days when I have them developed. I'm sure all of you can hardly wait.  :P
This is going to be kind of my progress diary, so bear with me.
DAY 1 (May 11, 2004): With assistance, the car gets towed to its new home. The journey was quite "interesting." Only a couple things to say on that:
1) Make sure the car being towed has brakes;
2) Make sure the driver of the vehicle towing the car knows:
   a) how to keep tension in the tow strap;
   b) the hand signals you will use (especially the one for "SLOW THE @)(*&(#&$ DOWN!";
   c) that she needs to pay attention (moreso than usual) to *everything* around her and to quit gawking at the buildings she passes, playing with her hair, and driving 45 mph when the driver of the towed vehicle is signalling to slow down;
   d) not to slow down sharply and then veer left on the highway causing the towed vehicle to pass on the right and break the tow strap (thank God it wasn't a chain).
Somehow, the car got onto one of the concrete work pads in my back yard without causing death or injury or even vehicular damage. The tow strap is, um, an unfortunate casualty. I took pictures of the vehicle from straight-on and 3/4 views. Also took pictures of the engine. These will be posted soon (when they're developed).
I jacked the car up onto jack stands and removed the front wheels just as darkness fell.
Regarding the original post of this thread, I know the following from reading the multitude of posts on this site:
0) Yes. Or at least the parts are interchangeable, which is really the main concern.
1) Maybe beefier front springs, but otherwise none.
2) Still curious about what transmission is in the Pinto. Perhaps a C3? Or would it be a C5? I don't know transmission IDs at all. All I know is it's a manual bolted to a 4-banger.
3) I'll probably bolt in an 8" Mustang II rearend.
4) Not going to worry about it. I'll just use the 4-bolt alloy sport rims.
Poison Pinto
Okay, I recently acquired a pea-green '75 Pinto wagon. The body is in reasonably good shape (no dents, plenty of rust). I intend to modify it to resemble the "Poison Pinto" die cast Hot Wheels car from the late 1970s (lime green, engine sticking up out of the hood, blanked windows, etc). Unfortunately my job has prevented me from having an opportunity to get the car to my own shade tree, and where it sits I haven't had much of a chance to look over the mechanicals to see what's what.
Soooo....
Although I've rebuilt and replaced engines and transmissions, my "expertise" with auto mechanics is replacing part A with another part A, this is my first attempt at a conversion. Basically, I need to know the following info:
0) Is the Pinto mechanically/structurally any way similar to the Mustang II?
1) What modifications (if any) will I need to make to the front end to support an '85 302? (I did catch the King Cobra mount PNs from another post, thanks!)
2) Will a C5 tranny mount up without major rework or is there a different manual tranny that I should use?
3) Does a 9" rear end bolt right in, or does this require significant modification?
4) What is the easiest 5-hole hub conversion?
Yeah, I realize all these are old-hat mods for some of you, but it will help me significantly to have these main points in one place to refer to.
And, yes, I'll post some before/during/after pics once I get the little gem out of the field where I found it.
Thank you for your time and your help.
