  • Online today: 314
  • Guests: 328
  • Total: 328
Granada Swap?
Started by 77turbowagon, June 20, 2007, 03:25:00 PM
Later Maverick rears have the same 2.75" as the Granada fronts.
turbowagonman
Quote from: 77turbopinto on June 21, 2007, 06:12:13 AM
Also, be careful, the Granada rotors need a wheel with a BIG center hole (2.75").
Good Info, I did not know that!
turbowagonman
The 'banjo' ends of the lines need to be bent slightly, and you should get the proper size nuts to install the other ends in the stock brackets too.
If you don't want to carry two spares, a later Maverick 8" rear is an easy (with minor work) fix, with bigger brakes.
turbowagonman
Quote from: 77turbopinto on June 20, 2007, 04:06:01 PM
When I got my kit from RJays, they did not mention what hoses to use, I had to figure that out for myself. I used 88 s-10 Blazer 2.8l 4X4 (the 2 wheel drive ones are different). I have this posted somewhere too.
I read that post, that is the only reason I said that. After I read that post I ordered & got my lines from my local Federated Parts Store.
turbowagonman
Just a note on the RJays kit, Please check to see if they work on the early ( 71-73) pintos before you buy the brackets. Most of the brackets do not work with the early cars. Of course if you have a 74 and up car its a mute point.
dave1957
 when i did my 5 lug swap on my pinto I bought 5 lug rotors from speedway motors.com..bolted right on ..and cheap at 29.95 each (they are not redrilled they are new ones)..thought this might help
1979 bobcat
1974 red stinkbug
77turbowagon
Thanks guys! That a pretty inextensive little upgrade there.
turbowagonman
Granada Rotors, GM Metric Calipers, 86 Blazer 4X4 Brake hoses and the brackets from RJays.com. I'll list the link here.
turbowagonman
http://rjays.com/Brakes/MII-Brakes-01.htm
77turbowagon
I've been seeing this Granada Rotor swap thing to get 5 lugs. What is needed to do the complete upgrade?
