Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 08/30/2018 12:59 am
Date: 07/17/2018 09:22 pm
Racing seats
Date: 10/24/2019 09:41 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Radiator
Date: 05/27/2018 06:07 am
Date: 01/12/2019 10:19 am
Date: 04/12/2017 06:57 pm
Date: 12/15/2018 02:21 am
  • Online today: 2,819
  • Online ever: 2,944 (June 18, 2025, 11:57:36 PM)
  • Guests: 2294
  • Total: 2294
Restoring my 78 Sedan
Started by dave1987, May 25, 2007, 01:09:26 AM
I have a crazy mind for cross referencing things....
I found the CORRECT style of ashtray light from a 78 Thunderbird. It mounts "inside the dash" on top of the hole in the top of the ash tray.
I went through about 40% of the 70s Ford/Lincoln/Mercury cars looking for an ashtray light, and most of them had it, but it was a light that hung down inside the ashtray from a plastic retainer.
I will try to get pictures, but have no batteries for the camera right now.
If you come across another ashtray light, I'm looking for one! I haven't looked at the wiring too much yet, my glove box light is just filling the hole. I have the wire to the pass dome light switch, but haven't gone looking for the plug (it should be high on the right under the dash near the windshield), I'm waiting on cashflow for switches from ssc. I seem to recall not finding a plug for a factory radio on my car, but I can't remember looking that hard  ??? I just hooked the wire under one side of the radio fuse in the fuse box and used an inline fuse.
Dave1987, you get the light thing figured out, maybe you can help me connect the cables back up for my heat/defrost.  Thankfully, I have the 1972 Pinto to use a model.  I can look to see how it's done, maybe I can get the 1971's hooked up okay.  Guess we'll see.  Larry :police:
I got the pump from an early 80s Mercury Grand Marquis, and the Pinto correct pulley from a late 70s Lincoln Continental! What a combo, huh? :P
I also found a couple glove box lights with the switch, as well as the ashtray lighting. Just need to figure out how to wire them up now! :D
Hey Dave:
My car has the original pump. It sounds like it's on oxygen when you listen under the hood. psh...psh...psh...psh. Other than that it doesn't make noise, but now I know what to listen for! ;D
Exhaust is on my list too. I wanna do the same thing, header and bigger exhaust. My exhaust is all original except the cat. I had it replaced 4 years ago, but the heat shield rattles and the tube hanging out the side (about 3/4 inch) doesn't go anywhere. My car sounds like it has an exhaust leak. The pipe is pretty rotted but the original muffler is there. You should post a u-tube video when it's done so I can see how it sounds! Money is an issue for me too, once again we're in the same boat!
My goal with my car: Luxury feel and Sports performance! (A bit of a sleeper too!)
Chuck :afro:
Pinto gets a replacement smog pump today, going out to the junk yard to get a good replacement. The one in the car is the original, and is clicking very loudly (bearing going out). I figure I'll swap it out before it seizes and breaks the belt!
I purchased a Pinto correct 77/78 front valance from CarlHarris (member here) yesterday, as well as a tube header with a 2.75" outlet on it! :o I will hopefully have the valance repainted and installed in the next couple weeks, and the header will be going on the car when I have the exhaust line rebuilt. The exhaust will be redone with new 2 1/2" pipe, new catylitic converter as well as a flowmaster 40 series muffler. Should have it sounding MUCH more throaty and closer to a V8 at idle, as I am wanting. Exhaust will be at year from now at the most, but if I can scrounge together the money to do it sooner, I will have it done by the end of the year! :D
The Pony got a new pace maker today....Alternator was on it's way out and clicking. Lifetime warranty exchange is helpful! :)
Chuck started a thread of his car when he first got it, showing his car in the "unmolested" state before he started any work on it. This gave me enough motivation to get the photos up, of my car, before it was ever driven on the road, and one of her with her first new car.
She requested to be blurred out of the photos, and I did that of my grandmother as well. The salesman (Dave), I think should be fine though.
I left them in as high a resolution as I could without destroying the photo quality. They have some spots on them due to the scanner's dirty glass, but the photos themselves are just like new!
Just think, how often do you get to see photos of your own Pinto, back when it was purchased at the dealership, and before it ever had plates on it? I find these pictures to be quite meaningful to the history of the car, and gives it just that much more character.
It's not much, but it is all I have of it right now. There are more photos, but perhaps I will get those from my mother for my b-day this year, like I did these ones last year!
Yes, that is a Mustang II in the background, another one of the cars I hope to own and restore one day. :P
Emmett Ford, the dealership, has since been closed. However the lot it sat on, and the office building, are still there. I plan to take my Pinto back down to Emmett this summer, sit the car where it was in these pictures, and take some updated shots with my 35mm in both black and white, and color film. I think it would add some interesting shots of the car for it's photo album.
dholvrsn: The radio plate came out of an 80 wagon I had about 4 years ago, it was modified (poorly) before, so I didn't mind finishing the job to add a cd player. I cut the roof off that wagon and used it as my yard truck for a year. It was liquidated with other cars and property when my illness started getting out of hand and I had to move in with my brother (no space for 4 Pinto's, an 87 Mustang 4 cyl and an 85 Ranger Pickup (also 2.3).
Dave: The dash looks awesome. I agree with you that the black/silver look goes very nicely with your car. Keep up the good work! :D
And a shot of the new dash look. What do you guys think?
Got the dash done today, and I think it came out great! It isn't perfect, but it looks really good. I will redo it when I change the windshield gasket and the dash for the spare one I have in storage.
Hey!!!!! the gauge cluster looks fantastic :amazed:.  Never used the metallic sharpie, that should help me restore my instrument cluster and heater control panel.  I was wondering how I was going to fill in the silver areas which had rubbed off.  I just love this web site, I find a lot of useful information from others.  By the way, your car is fantastic.  Larry :police:
Good to hear that this will provide a reference for others! The one noticeable thing that I will be doing, is sinking the face of the gauges into the trim, rather than having the black trim of my gauges sit "on top" of the trim.
Very cool Dave! I just installed the a/c style console in my car, I'm planning to put gauges in the opening where the heater control would be, but hadn't figured out how I would trim the face. That's inspirational, and I may 'borrow' your technique to create a face for my gauges. ;)
This is before I added the wood trim from a 72 to cover the hole.
Wow, that looks great Dave!!!! Now that you are a pro, I will have to find another dash piece to send to you, so you can make me one!!!! LOL I am getting used to the gauges being in the dash, may keep them in there now!!!! LOL Just need to find a clock or amp gauge!!!! LOL
Good work!!!
Well here is the work completed so far:
I cut out the holes with a hole saw slightly smaller than the face of the gauges, then used a file to enlarge them. Well, the plastic is softer than I anticipated and it ended up distorting the holes in spots, and I had to patiently fix the problem areas with bondo, a small razor blade, and some 320 grit sandpaper.
After the fine repairs, I painted it using satin black Krylon plastic paint, "drew" the silver stripes on with the metallic sharpie, and then clear coated with Krylon satin clear coat. A few of hours later, here is what I got:
I am "extending" the plastic around the inside of the holes to round them out after the rough filing job. So far it is coming along great. I'm taking my time with this so it comes out right. I would get frustrated and have to do it all over again if I kept looking over at my temp/oil pressure/volt meter gauges and seeing it all messed up.
I will post pics when the panel is done, as well as once it is secured to the dash!
I did use a hole saw, but the gauge face is slightly larger than any of the hole saws available, so I used a file to make the holes slightly larger where needed. Now the holes are rough around the top edges and too big in some spots. Somehow, I need to fill in the empty space, as it looks really tacky.
What are you using to cut the holes?  I would  use a hols saw and a drill press  with a block of wood behind (under) it should give you a very nice clean hole.
Hole saw kit at harbor freight  on sale  about $5
Phil
I got the seat hinge covers on, with some effort. The steel (or is it iron) they use for the pivoting elbow on the seats is very hard to tap. I drilled the holes for the screws starting at the smallest bit, then working my way up to 1/8". Once I was there, I had to tap the hole for the securing screws, and ended up BREAKING one of the tapping bits! I had to get another big and re-drill the hole elsewhere. Lucky me, the one I started with was actually off by 1/8"!
Right now the seat hinge covers do nothing cosmetically, aside from the small bottom half of the hinge that shows past the seat covers. I can't wait to get my original seats re-upholstered!
I started on the dash panel that pintogirl sent me. I have the wood grain polished off, touched up the silver edging, did the cut outs for the gauges, and mounted the Pinto dash emblem. Only one problem, two of the three gauge holes are messy around the top and I need to find some way to make some cleaner looking. I'm thinking of pulling out the Bondo and adding to the holes to make them smaller, then sand away what is necessary to make it look right. I'll get it figured out some how, but any tips would be greatly appreciated.
They do ride quite smoothly for a compact sedan of the 70s. The only thing I might change would be softer shocks....Classic brand are pretty stiff. I wouldn't mind some Koni's. 8)
Quote from: dave1987 on February 23, 2009, 11:16:42 AM
Thanks Larry, and glad to be of help!
I just got back (about 2 minutes ago) from dropping the Pinto off at Les Schwab for a thrust alignment. First time the car has been in a shop in nearly 11 years!!!!
I'm worried about other people touching, er, working on her, and have this nervous anticipation feeling in my stomach. I think pintogirl and blupinto would know what I'm talking about! lol
I can't wait to get her home and drive her with the new front end! :D
UPDATE: The car is home again, and drives straight when I let go of the wheel! :D The only adjustment they had to do is the toe out and pull it in a bit, drives like new now! :)
Yah, I know what you mean. Hubby's kid installed my windshield when I wasn't home and he put the chrome trim on. I wasn't happy about that. I would have prefered to do that myself. In fact I did take it all back off and re did it because he had it on wrong.
Congrats on the like new ride!!!! I have to say that hubby was quite suprised on how the Pinto rides. He said that if felt more like a luxury car!!!
Dave:
Hey thanks, but since I know the Mustangs and Fairmonts have them, I too will look locally.  If I don't find them, I'll let you know.  I already have one, which I got with the purchase of the seats in Greenfield, but one was missing.  If I can at least find them for the 1971 I'll be happy.  Thanks for your help, I was wondering what I was going to do about those covers, as I really wanted them.  Your car looks great.   Larry :police:
Thanks larry and beegle55!
Larry, I found my seat hinge covers at the junk yard. They came off a 79' Mustang, but I also noticed that the fairmonts at the junk yard have them too, so they would be worthy candidates too! If you like, I can go out and pull a set when the weather clears (it's raining here for the next few days).
The set I am going to be using is originally white, but I am painting them black using some SEM paint.
Dave:  The air conditioner shield looks fantastic!!!!!  You have a sweet little Pinto there.  I too want to put the seat hinge covers on (not sure if that's what you call them), but I only have one (for the 1971).  Did you get yours at a salvage yard?  Or did you purchase them as new old stock?  I'd like to purchase some for both my Pintos, could you tell me how you acquired them?  I went to the shop yesterday, and they're still working on the ball joints of the 1971.  I'm really hoping to bring her home by next weekend. Once the weather breaks, I'll be working on her till she looks new again.  I'm hoping to take her to her first car show in April.  Anyway, keep up the good work, you've got a great piece of Ford history there.   Larry :police:
Good work! The shield looks great and I'm glad to hear that your Pinto will be in great driving condition soon! Fun times await...
Thanks for the compliment Chuck! I'm sure you will find one, it is just a matter of time. I will keep an eye out as well.
I got the ball joints done yesterday afternoon. Scheduled an alignment for Monday at 10AM, and I will also be asking them to install the new rack and pinion bellows, as I have had enough with pickle forks for one year, lol.
Once that's done, the car will be road-trip-worthy again! Bring on the summer cruise nights! 8)
Thanks for the advice (hopefully I'll see another one someday). The interior looks great! I like the hybrid shifter and the way the MII console nestles the factory cubby hole.
