Date: 02/16/2019 10:46 am
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 09/20/2018 11:01 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
Date: 05/22/2018 01:54 pm
Date: 07/20/2017 01:23 am
Date: 05/18/2020 10:22 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
  • Online today: 2,909
  • Guests: 2717
  • Total: 2717
Restoring my 78 Sedan
Started by dave1987, May 25, 2007, 01:09:26 AM
Well I couldn't track down where it's coming from on the OUTSIDE, but I did see where it is dripping on the INSIDE. The left most dash mounting tab underneath the windshield gasket lip. That's a mouth full! lol
Here are some pictures:
1) Dripping Point
2) Direction of water travel
3) Final dripping point onto the floor
Thanks man. I know my rear window leaks a little bit. Just waiting to find either a good gasket that I can pump with sealant after installing, or some good glass. If I find good glass, I'll just break my rear window (it's terribly scratched as it is :() and replace the glass, reusing the original gasket with sealant.
Rear window does leak to badly right now, only in a really bad down pour.
Good luck man.  I struggled for quite some time to get my crusing wagon water tight.
Gonna try tackling the water leak under the dash again today, after work. With all of the rain, the driver's side floor mat (rubber) fills with a puddle of water, every night. :(
When I did the heater core, I removed the rest of the rotted insulation that was under the dash. What used to be a thick insulating material had turned into a crumbling wonder of brown fluff! This insulation used to be stuck under the dash along the wiper post section of the cowl, so I am suspecting the wiper post seals are gone.
I will be pulling the wiper posts and the motor to replace the seals with some nice ones I pulled from the 78 bobcat this spring, and I will be putting some sealant on them to just to make sure it doesn't keep leaking. My windshield gasket has a few small cracks, but nothing really bad. I sealed it up with some silicone sealant last year and it didn't help at all, so my strongest bet is the fresh air ducts or the wiper system.
Wish me luck!
On a side note, I did get the good insulation from the 78 bobcat this spring as well, which I will be sticking up there once I am sure it's not leaking.
For the pictures below, the first one is of the old insulation from the cowl. The left is the old deteriorated crap, and the right is the good material from the bobcat.
Second picture is what I found in the heater box when I tore it down. Not to bad for 31 years!
Thanks Chuck! Nope, not the whole car, but you can definitely tell where it has been painted if you are really admiring the car. It's pretty dark compared to the trunk lid, but the guy did a great job blending the paint across the quarter panel up to the door!
The mist from the clear coat was ALL OVER the car though, which was not fun to buff off. :(
Looks very good! You didn't need to respray the whole car after the quarter repair, huh?
Congrats on passing your emissions test!
:afro:
The paint is actually a 1992 Jeep color, Canyon Blue. My brother repainted it in autobody class during highschool.
Sherwin Williams - Ultra 7000 Series Paints
1992 - 1992 Jeep - Code: AY96KC3
Canyon Blue Metallic
That's the paint type for those of you interested!
I agree, it looks great!!
That is the color of Pinto I need to find, but it needs to be a 71-73 sedan!! LOL Once I find that one, my search for Pintos will be over! Ok, I'm hoping LOL! Anyway, your Pinto's color is the color my parents had when I was younger and I'd like to build one to look just like theirs!  ;D
Needed to post some updated shots! :)
Yup the pass side wiper post is what took out my pass side floor pan in my crusing wagon.  I used that black clay caulk stuff from 3m to seal both posts.  It comes in a small box with a bunch of 12 inch or so strips
I got the heater core changed out yesterday after receiving my 73 wagon.
Replacing the core was a five hour task, less than I expected actually!
I redid the seals on everything and new hoses as well.
It doesn't heat up any quicker than before, but it doesn't stink anymore!
I can't fully test how well it works once the thermostat opens, since the car won't heat up to 190 degrees with the weather we have had (to cold outside). It gets up to 160, and stays around there. If I drive 35 mpg in third gear for long enough it eventually gets up to 190 where the thermostat pops open, but quickly cools back down enough to sit at 160-170, after wards.
While having the heater box out, I did a visual inspection of the firewall from the inside, the cool air intake hole as well as the cowl from inside. No rust at all from the inside, and I cannot find any traces of water leakage on the passenger side. I'm thinking the leakage I have on the driver's side may be coming from the wiper posts.
What material should I replace the existing wiper post seals with?
Haha, I guess you saw my post in pintogirl's thread! :P
I'm guessing it's plugged up or something. I hope it helps, I really do!
good luck and maybe that will fix the heat problem  mine gets very hot in only a few minutes  like less than 5
I'm planning to remove it the way Haynes instructs. Unbolting the blower motor from the outside of the firewall, then disconnecting the defrost ducting, following up by removing the entire box assembly while pulling the hoses through the firewall. Seems easy enough, but nothing on this car is. lol
I do plan to remove the passenger seat, glove box door and insert as well as the under-dash AC shield I installed, so as to gain easier access during the removal procedure.
Once the box is out, it's off to A Radiator King in boise to have them pressure test the replacement core (they only charge $5!), and then to O'Reilly's to get new hoses.
good luck and most recomend removing the seat  better access  while laying on your back working under the dash.
Eww! Pinto smells strongly like antifreeze inside the car when the heater is first turned on and very slowly dissipates. Looks like it's time to swap out the heater core for the spare I pulled from the Bobcat year year. :( Not looking forward to this next Wednesday.  :'(
I'll take the spare down to Radiator King and have them pressure test it and clean it. In the mean time, I will pull the heater assembly out and clean it all out (I'm sure it's full of crud) and fix the door seal.
Anything special I should know aside from what's in the Haynes manual?
Here's a picture of my car at the local Patty's Burger Time Cruise Night I frequented every Saturday this summer (2009). We had a professional photographer there every other week and I managed to get my car in a few shots. Unfortunately, this is the best of the ones with my car in it. What matters is that it's getting some attention! :D
http://hotrodhigh.zenfolio.com/p403991680/h38d146c3#h38d146c3
Yay!!!!!!!  Always excited when a Pinto clears an obstacle.  Congratulations.
Larry :police:
Quote from: dave1987 on October 22, 2009, 08:41:34 PM
My Pinto passed emissions again this year! YAY! Only took one try this year instead of 13 tries! :P
New Air Filter
New Oil
Retarded Timing A Few Degrees
Fuel Air Mixture Leaned Out (Until motor shivvers)
Adjusted Curb Idle To Compensate For Lean Mixture
Easy as pie this year! :)
Now I just need to get those photos up!  :mad:
Congratulations to you AND your Pinto!!! :drunk:
New Air Filter
New Oil
Well my adventure has been put on hold. Not enough money for gas. Yeah it's only about $15 in gas to get around to these places, but right now that's what I am using in four days of driving to and from work. :(
I WILL get these pictures done before the end of the year, I promised myself (more like a new year thing) that I would.
Finances are really bad right now. :(
Taking all those pix, in front of hold homes and businesses, is something like I would like to do.  Great idea...I still have some of the old shops around where I live, where I use to have work done and such.  I'm gonna do the same thing....I really enjoy going into my past, and remembering my childhood.  It was a great one..I was fortunate.  Larry :police:
Roof rack plans put on hold. The roof strips have the mounting strips inside of them rusted away at the hold down points, so I will either be finding some inner strips in better shape, or modifying them to make them work.
Saturday is the car show, I will be cleaning up the car tomorrow to get it ready.
I will be going out to Emmett in the next couple days (Sunday after noon) to take picture of the car at the dealership where it was purchased. On the way home, I will meet up with the owners of my mother's old house in Eagle and see if they won't mind me taking some pictures of the car in front of their home that are similar to the ones my mom gave me. After that I will be heading back to Meridain and take a picture of the car at my cousin's old Cheveron Service Station which is now a flower shop. It is where my mom had 99.9% of all the service dones on the car. Last stop will be just down the raod from where I am currently living to get a picture of the car in front of my parent's first home where I grew up playing in the car. I will post pictures when I get them uploaded and touched up. :)
yeah they Secure with tube nuts and the racks on the wagon and hatch/trunk are the same
Hey Dave!
In my experience with the wagon roof rack, there's a 'tube nut' similar to what holds the mirror on the car that the screws secure to. The wagon didn't have any additional supports in the roof. We took a rack off my mom's 82 Escort wagon and put it on her 80 Granada, the rack should flex some, I'd think. Move it around to see how it looks before you screw it down.
Chuck :afro:
Well I am back on the road again! The car still needs a new steering rack and windshield gasket, but all in due time.
I managed to nab a roof rack from a wagon for $14.99, but I am not sure if it will fit well on a Sedan. Is it possible?
Also, the roof strips "under" the rack are two pieces; the chrome on top and the securing bracket inside it. The two inner strips have the inside securing bracket rusting into pieces at the mounting points. Is there any way to repair this or should I just look for two new strips??
I only plan to put a roof rack on the car since the clear coat on the roof is peeling madly and just looks ugly. The roof rack should detur a lot of it, but I see myself using it a lot in the end.
One more note on the roof rack. Do I need to reinforce anything from the inside to keep the roof from collapsing when items on placed on it?
I'm up and running Dave! :fastcar:
Hope you will be soon. Best wishes! :)
Chuck :afro:
Thanks r4! I'm just glad she's still in one piece. I'm in a slightly similar situation as Chuck right now. Registration expired on her and I can't afford to re-register, so she's sitting in the parking lot at my apartment complex getting paint misting buffed off her and the bumpers removed and slightly buffed. I plan to replace the scratched up door handles while she's parked, as well as fix my seat belt buzzer wiring. Hopefully she will be back on the road soon, it's depressing seeing her bake in the summer sun and not go anywhere. :(
Dave, looks good. It's still a shame but atleast it wasn't any worse than it was.
