1975 mercury bobcat
Date: 08/14/2018 03:40 pm
pintos for sale
Date: 12/11/2018 04:29 pm
nos core support
Date: 01/03/2020 09:39 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
1979 PINTO PARTS--FREE
Date: 09/13/2022 02:05 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 12/26/2016 04:29 pm
  • Total Topics: 16,268
  • Online today: 152
  • Guests: 126
  • Total: 126
EFI in a pinto?
Started by waldo786, May 22, 2007, 10:59:27 AM
Quote from: waldo786 on May 23, 2007, 10:33:27 AM
Thanks for the all the info again.  When you say modifications, are you referring to the computer, sensors, etc. or other modifications?  It might be simplest to do a throttle body injection swap.  How good are these heads and intake for flowing?  I know it's just a 4 banger, but I like the reliability and drivability of FI.  Is there any kind of aftermarket out there for these engines?  I'm looking at a '77 hatchback with a 4 banger 4 speed.
Answers in order:
1) Yes, and some cutting and drilling to the car.
2) From what?
3) Not very.
4) Yes.
Almost anything you do will require you to do custom fabrication/modification somewhere (IE: Where do you plan to put the fuel pump? how are you going to make the hood close? Where are you going to mount the ECU? How are you going to install the 02S? How are you going to connect the fuel lines? There are hundreds more.)
With enough time and money, anything is do-able. You need to look at your goals, and decide what direction to go.
waldo786
Yes, the EFI intake will bolt to the N/A engine that is in a Pinto IF you drill and tap one mount hole. Keep in mind that you will need to make a few modifications to the car as well.
waldo786
Thanks for all the good info.  I do have another question though, if I don't want to have a turbo, will later heads from the 2.3L and or intake with efi fit on the block?  Could I do a conversion that way?
fomogo
The 2.3 EFI turbo is a popular swap. The engine generally comes from a thunderbird turbocoupe or merkur XR4Ti.
You could swap in a naturally aspirated 2.3 EFI out of a mustang.
The wiring is not too bad and you will need to run the EFI fuel pump and lines.
Jim
www.turbopinto.com
waldo786
I'm curious if anyone out there has put EFI in their pinto.  Will set ups from later model engine's work, and if yes what cars/years will work (for the 4 or the 6)?  I could always get one made from the components.  Also is there much info o aftermarket on how to get more power out of the 4 or 6 cylinders naturally aspirated?  Were these the same engines in the mustangs for a while?  Thanks!
