Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
postal pinto
Date: 06/03/2020 09:31 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
78 pinto wagon
Date: 03/03/2020 01:07 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
1973 Pangra
  • Total Topics: 16,272
  • Online today: 186
  • Guests: 146
  • Total: 146
Pinto motor questions
Started by Pintogal, May 10, 2007, 12:47:56 PM
PintoGal,
I agree that rebuilding the 2.0 that is already in the car would be a better route and easier then installing a 2.3. A Pinto on the road is better then two in the garage.
Quote from: pintoracer02 on May 27, 2007, 07:25:33 PM
what makes a german motor so great?
Race motors do not have hydraulic lifters!
pintoracer02
what makes a german motor so great? Personally weve raced the 2.3 with great sucess and I love them. Plus you dont have to order any parts because their real popular in the mustangs too most parts places carry most everything for the 2.3.
Bass Ackwards
Hello Pintogal,
The 2.0 engine in your 1972 Pinto is a better engine than the 2.3.
Y would you want to swap it out???
Just re-build the 2.0!!!!!!
The 2.0 came from GERMANY...
Everyone knows they make great engines.
Pintogal
Thanks for the info, I guess I need to do some homework before I do the swap!
Cyndie
1972 Pinto Trunk model
onefarmer
I put a 2.3 in a 71 once a long time ago. I just used the 2.3 mounts and welded them in place. No further mods as to width. Just put the frame mounts on the engine, drop the engine in, bolt up the trans, driveshaft, ect .... then determine where the engine should fit as to height and weld the mounts in. For the radiator clearance I milled the fan spacer down so it was about an inch long and it worked quite well. It was closer to the pulleys but it still cleared. All this was done in maybe 1979-80ish when pintos where still everywhere.  :text_yb_warning: This info guarenteed upto the amount you paid for it. Your milage may vary
I am not sure if the framerails are different but I do know for a fact that the later cars (74 up) had a different radiator support in order to clear the physically longer 2.3L engine.  It will fit in the early engine bay, but you may find that fitting the radiator may be an issue unless you run an electric fan on it.  I know there are folks on here that have done it, so maybe they can give some good pointers.  Try to do a thorough search and read what others have posted.
Good luck!
turbowagonman
I think they changed the Width of the Frame Rails in '74' to accomidate the 2.3. So I'm not sure if it is a direct bolt in. You might need to make some custom Motor Mount off the Frame and and I'm also not sure if the Motor Mounts (on the motor) are a direct swap, maybee though. I'd think it has been done before, it's just getting the Info or just seeing if it will fit. Measure the Motor up and Measure the Engine compartment and see if the numbers are compareable.
turbowagonman
Pintogal
I have a 1972 trunk model, now that the weather is improving I'm back to working on it... Question is I have a 2000cc motor in it that is really tired.  I also have a 1976 pinto with a 2300cc.  Is it an easy swap or should I stick with the 2000????  any recommendations would be appreciated  :)
