Date: 02/14/2018 01:34 am
door sills
Date: 03/14/2020 03:20 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 08/22/2018 09:23 am
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 10/02/2017 02:16 pm
Date: 08/17/2022 06:27 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
  • Total Topics: 16,272
  • Online today: 186
Oil pan removal
Started by CHEAPRACER, April 10, 2004, 10:43:10 PM
CHEAPRACER
I removed it about 2 days after the original post. Very simple, drop the rack, remove the starter, and it almost falls out. I also used new original cork side rails with nothing but silicon on the ends, let it dry for 2 days and no more leaks. The late model blocks use a 1 piece rubber gasket that is pushed out easily using the earlier Pinto pan and the early model gaskets won't work on a newer block. I found this out the hard way after seeing lots of smoke out the rear.
vbmdu
Never done it, but did a 2.8 V6 once. Never again!
Just remove the two bolts for the rack and the steering shaft, then push it down out of the way. I cant picture the room in there, but you can always loosen the motor mounts and raise the engine up with a jack on the crank pulley. Better steam clean it first though.
CHEAPRACER
Can it be done with the engine in the car? It looks like I may have to remove the steering rack and it may come right out.
 I didn't find out about the different sized rear main caps of the later engine until it was too late and installed an earlier pan on a late model engine with no sealer or pan modification. Now I have mucho oil leaky. Thanks.
 I forgot to mention it's a '74 with a 2.3
