73 Runabout
Date: 11/20/2017 03:19 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 09/22/2020 11:33 pm
New cam
Date: 01/23/2017 05:11 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 08/16/2018 08:54 am
  • Total Topics: 16,268
  • Online today: 160
  • Guests: 127
  • Total: 127
transmission swap question
Started by lyndensv82, April 17, 2007, 10:07:15 PM
For the 2.3 (you didn't state which engine other than "V-8" ??? ) most use the bell crank style.  Don''t even consider the 87-88 Turbo Coupe housing as it is hydraulic and not readily adaptable.
Reversing the crossmember and slotting the bolt holes will work (especially if you don't have welding capabilities).  See picture.
  Also included (picture) is a bracket I made to better position the clutch cable when used with the "bell crank" bellhousing. I did weld an anti rotate tab on incase the bolt came loose.  It bolts to the original hole and elevates the cable over the crossmember.  The arm on the bell crank need to be bent slightly outward.
Tom
wedge446
Quote from: lyndensv82 on April 17, 2007, 10:07:15 PM
hello  i woud be grateful if someone with experience tell me which borg warner t-5  world or non world class will be a direct bolt in.  right now im using a mustang 2 v8 bellhousing and v8 4 speed.  thanks in advance.  lyndensv8@yahoo.com
Dont know if this is much help but I got a T-5, bell and flywheel from an 86 mustang 2.3 turbo and it bolted in but I had to re-work the cross member for the transmission mount.
I cut the old mount pad off the cross member and welded a 1/4" flat plate with slotted holes. ease to do if you have a welder
lyndensv82
i used a mustang II bell,had to enlarge the the hole about a mm.works great
Scott Hamilton
lyndensv82
