Date: 01/24/2017 12:36 pm
Date: 08/20/2017 01:34 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 01/19/2021 03:56 pm
Date: 02/14/2019 06:27 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
  • Online today: 2,670
  • Guests: 559
  • Total: 559
MII hedman headers work well?
Started by gearhead440, March 26, 2007, 11:53:27 AM
gearhead440
Mr. Pinto,
Thanks for the advice and info ;D.  Looks like the headers are a go.  I suppose I could attempt to install the engine/trans and headers as a unit.  High_Horse has some good pics of his install with exhaust manifolds and head pipes and your testimonial of fit adds a level of confidence to the project.   8)
GH
mrpinto
No cutting ,but I did put a few tiny dents here and there around the rag joint part of the column. I also modded my engine bay a little for "extra" clearance (smoothed out the high part over the control arms), but it's not absolutely necessary.
I also install them bolted to the engine, as one unit.
Never bottomed them out or hit anything with them.
Take your time, you'll get them in there! ;)
1979 302 Pinto Custom
1971 460 Drag Pinto
gearhead440
Mr. Pinto,
Thanks for the reply!  Since the do fit in the bay, is there any cutting required to make them work under the chassis and is ground clearance a problem?  I would like to use them but it they scrub the ground regularly or bang every time you go over a speed bump I wont be able to use them and will just use manifolds.
Thanks again.
GH
mrpinto
I'm using MII headers with my 302 w/ C4. They are tight, and are a little tricky to install, but they do work.
1971 460 Drag Pinto
gearhead440
Jegs has MII 302 Hedman Headers listed for $140.  Does anyone have experience with these in a Pinto and is there a lot of creative fabrication required to use them?  I'll be running a 302 with T5, BTW.
Thanks
