1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 01/23/2017 07:41 am
Date: 03/07/2017 07:03 pm
Date: 05/15/2022 11:36 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 01/19/2020 09:06 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
  • Online today: 586
  • Guests: 232
  • Total: 232
8" rear brake drums
Started by mrpinto, March 06, 2007, 01:47:39 PM
billnall
Try 90 Ranger to see if it has the same center hole.
Ford Parts Man
Maybe get a set of 4 lugs and get them drilled??
The MOST CRITICAL thing is that the CENTER HOLE is correct; that's what centers the drum on the hub. The next is the offset/width.
Here's a wrech for the works: Ford had some 8" that were 4 lug, but unlike the Pinto's 4.25", they were a 4.5". This would make converting these drums to 5 on 4.5" VERY easy.
I don't know of an application for a 5 lug 9" drum. Maybe an autoparts place....
mrpinto
Quote from: 77turbopinto on March 10, 2007, 10:15:22 PM
If I am reading this correctly, you are saying that the rear was converted from 4 lug to 5 lug, and you are looking for a DIRECT application for a "replacement" set of 5 lug drums?
Well that's the thing. I'm not 100% sure. I "think" the rear is originaly a 5 lug rear and the last guy who owned it used 4 lug drums, and cut out more holes to fit the 5. I just need  a pair of 9" 5x4.5 brake drums and not sure what cars came with them so I can order a set.
1979 302 Pinto Custom
1971 460 Drag Pinto
mrpinto
Anyone know what cars used this size brake drum? Having a hard time finding drums for this thing.
1971 460 Drag Pinto
mrpinto
Exellent. Very much appreciated.
1971 460 Drag Pinto
billnall
Ford Parts Man
mrpinto
I have a 8" rear, not sure exactly what it was out of. A Maverick I. It has 4 stud brake drums that have been cut out to fit 5 lug. I want to buy new drums but I'm not sure what to ask for. I measured the drums and they are 9" measured on the inside (where the shoes go) or 10" measured from the very outside. And they are 2" deep measuring where the shoes sit.
Are these considered 9" or 10" drums?
1971 460 Drag Pinto
