Date: 08/09/2018 07:49 am
Date: 07/08/2022 11:51 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 02/08/2018 02:26 pm
Date: 09/09/2018 03:22 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 04/08/2018 05:47 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 03/17/2019 10:15 pm
  • Online today: 642
  • Guests: 453
  • Total: 453
Difference between wagon wheel well moldings and sedan/HB wheel well moldings?
Started by TIGGER, February 25, 2007, 10:53:50 PM
Thanks Bill that is what I needed to know.  I figured out the difference between the front and 79-80 but was having a hard time finding out what the difference is between the sedan/HB and wagon rears.
First, if they are the wide ones for a sedan/H-B, I'll take them.
Second, there are the narrow ones and wide ones; all I know about is the wide ones.
There are 2 different ones used for all 4 corners for different years and models. All the fronts are the same until 79/80, these look like the pre-79's exept the forward part is longer (I will look to see for an easy way to to tell). Ther rears are all the same for H/B's and sedans, but he wagon ones are longer in the rear part (can be ID-ed by the lower rear mount hole being a couple of inches above the bottom of the trim where the h-b/sedan ones have the hole closer).
Photos are of the wide style ones.
One photo shows the lower rear edges of a wagon and a non-wagon right rear wide molding; the one to the left is the wagon one. The other shows two left fronts; the one in the wrapper is a 79/80.
I was going thru my stash wheel well moldings today and ran across some rear moldings but I am having a hard time figuring out if they are wagon moldings or sedan moldings. I even tried to fit them to each body style, without mounting them it is kind of hard to tell?  Is there an easy way to tell?
