  • Online today: 1,293
  • Guests: 1036
  • Total: 1036
What spring rates should I go for for a road race type of setup?
Started by ahawes, January 10, 2007, 11:49:23 PM
ahawes
Yea I will be upgrading to some Koni shocks at the same time. Thank you for the tip!
Adam
71 Runabout
remember though that the stiffer the spring is the more damping you will need in the shocka absorbers especially it you drive it on the street.  the stiff springs and a weak shock will see you driving down the street like you were porpoise jumping out of the water
Blacksheep22
Im not a road racer but I ran circle track for 10 years in mini-stock so Ill give you what I had.
I ran a 3/8ths mile asphalt with banking somewhere around 20 degree's. Running a 71 Pinto with a 2.0 in it. (see avatar) Got the 1994 Championship and still hold the track record to this day with the most wins in a season in any division there. 26 out of 32.
I ran Landrum springs as the ones they have for the mini-stocks set my ride height perfect. http://www.landrumspring.com/ I had a #700 in the right front and a #600 in the left front. I also ran their #125 rear leaf springs. I just checked the site and they still offer the leaf springs but you may have to call them as I didnt see the mini-stock coil springs listed but I would say they still carry them. Hope this might help a little.
                                                       The Blacksheep #22
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
ahawes
I am planning on buying some new springs to replace the original ones under the 71. I plan on putting some sway bars on the car in the future as well to further stiffen up the handling. Racer Walsh has a wide variety of spring rates available, what would be the best spring for a nice stiff ride? Im sure that at a certain point going to heavy on the spring would be counter-productive and I don't want to cross that line. I don't mind a stiff ride as long as the car handles well. Anyone have any insight?
Thank you
Adam
71 Runabout
