13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 04/28/2018 04:12 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 06/25/2021 12:59 am
1972 pinto grill
Date: 02/27/2018 12:13 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 03/16/2017 10:00 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
  • Total Topics: 16,268
  • Online today: 200
  • Guests: 173
  • Total: 173
73 ingnition
Started by rctinker, December 29, 2006, 02:14:47 AM
Hi.  Hey, you might want to see if earthquake still has the column in his 73 parts car.
--Doug
rctinker
Well the key is stuck in the ingnition, the ignition rotates really stiff, the ingnition key release lever doesnt want to move much or release the swith and on top of the colum where the instrument cluster and the colum meet there is a metal rod with a loop sticking out and you can push/pull it in and out. The 2.0 is not running right now, the car has been sitting since 1986 and I'm doing a bunch of pre start maitnence and clean up before I try to get it running. But before I put a battery in it I would like to find out whats up with the ignition, or find another complete colum to swap in.
Thanks,
Robert
1977 Crusin Wagon when I was 16
The electical part that connects the column to the wiring harness is different.  I am not sure if you can swap out the switch that is on top of the steering column.  I have not tried it, but I know the switch on the 73 has to be set just right to work so be careful if you take it off your existing column.  What is wrong with your existing column?  Depending on what is wrong, you may have to piece them both together?  Good luck!
rctinker
Just picked up a 73 runabout, not running at this time. Looks like the last time it was registered was in 1986. I need to know if a complete steering colum from a 78 will swap in with no problems.
Any help will be appreciated.
Thanks,
Robert
