Date: 10/03/2018 02:00 pm
Bumper Guards
Date: 03/28/2017 09:27 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Date: 08/24/2018 02:50 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 12/10/2016 04:11 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 11/23/2017 05:44 pm
oldskool787
Date: 02/12/2017 12:42 pm
  • Online today: 1,181
  • Guests: 708
  • Total: 708
78 wagon wont run
Started by windworkerusa, December 28, 2006, 07:56:12 PM
Quote from: douglasskemp on December 29, 2006, 12:23:34 PM
Hey Tig, The switch on top of the column...That IS the ignition switch.
;D
--Doug
LOL you posted while I was typing out my response.  I got the warning and chose to ignore it and post anyway because my son was crying.   :sorry:
My 78 cruising wagon did the same thing. The ignition switch is located under the dash. One must drop the steering wheel to get to it. Ya, I played the crank and let off game for a while but your car has to be really tuned well to get away with it. Pintony posted some numbers. Just change the linial switch...Done deal!
Hey...My steering wheel just happens to be dropped...heres a picture.
;D
--Doug
Try also the ignition control module first, can get one for $20 and its alot easier to install. My 76 had a similar problem except it would fire after i let off the key while the engine was still spinning from residual energy. Thus it wasnt turning fast enough to start but it would spark atleast. If id left the key in run and sparked across the solenoid, or push started it, it might have started but i didnt think to try that. Anyways, its something to try. If it doesnt work, its only $20 (atleast for mine it was). Another possibility is a bad engine ground. Make sure the ground strap is connected from the throttle cable bracket to the firewall. Thats where the ground strap is at on my 76 atleast. Both the one i have now and the one i had in the past.
Another 1-UP for Tigger... ;D
Do what Tigger suggests.
Motorcraft part # SW-1380
STANDARD MOTOR PRODUCTS Part # US-90
   AC DELCO Part # US F1457
I had the same problem with my 73 hatchback earlier this year.  It ended up being the switch on top of the steering column near the pedals.  If you drop the column you will see it.  There is a metal rod that connects to the key.  When you turn the key, the rod moves down and engages the switch that sends power to the appropriate place.
Might also be a bad ignition switch.  Happened on my old 78 sedan.
--Doug
73pintogeek
 :welcome:
Try spraying a little silicone lube in the ignition key hole and around the switch lip to get some inside...sound`s like it`s a little sticky from sitting...don`t use WD-40 as it`s a dust magnet...Hope this help`s!
A bad day workin` on my Pinto is better than a good day at work!
windworkerusa
just got 78 pinto crusier wagon, low miles, been sitting, runs when key in start, then dies when key in run, help?
