Date: 08/13/2018 02:46 pm
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 05/13/2021 05:33 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
New cam
Date: 01/23/2017 05:11 pm
Date: 03/25/2019 09:02 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
  • Online today: 1,438
  • Guests: 135
  • Total: 135
v8 engine swap
Started by 71scj429, November 21, 2006, 04:31:15 PM
don't have it off hand, but you can search it out on the web.  They are available in reverse rotation and standard i believe.   Jeff
71scj429
IS THE FORD MOTORSPORT SHORT WATERPUMP REVERSE ROTATION? COULD YOU GIVE ME THAT PART NUMBER? THANKS, SHAWN
you can use any pump from a passenger car.  Truck pumps are sometimes longer.  I'm going to be using a ford motorsport short pump and pulleys to gain an extra 1.5 inches between the pump snout and rad.
71scj429
does any one know what water pump to use with a v8 pinto install mustang II?  what pulley set you can use? I'm looking at 1 belt needed to turn waterpump and alt running off crank shaft,is there a good under drive pulley set out there someone can suggest?
