Date: 07/08/2017 08:53 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 01/20/2018 07:51 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 04/12/2017 06:57 pm
72 PINTO WAGON
Date: 09/23/2018 06:16 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 11/05/2020 06:32 pm
  • Online today: 1,972
  • Guests: 1000
  • Total: 1000
ThunderPinto gets an Interior.
Started by High_Horse, November 19, 2006, 01:12:45 AM
Pic#1>>>Assembled the pod front and put in the side panels to be able to get a finish cut measurement on the Pod cover. It will have a  1/2" gap as so the carpet can be adhered around and under the covers edge.
Pic#2>>>The cover will be held down by 8 magnets(4 on lid, 4 on faceplate) The Pic shows the top magnet in position being adhered to the cover with RTV. Also indicated is the position of the corrosponding faceplate magnet which has already been adhered and covered with carpet. There won't be any rattling going on here.
Lookin GREAT High Horse. MUCH better than mine, for now anyways. I like that you found a good use of school books too ;)
Pic#1>>>Well, I got goofing around again and decided to roll my own door threshold strips. I was going to use a rubber face but went with some peices of headliner material. The thresholds are mild steel with a rust preventer and then the material adhered, folded over the outside edge and butted up to the interior carpet.
Heavy Duty.
Pic#2>>>A different shot. It's the details that make the job detailed.
Pic#1>>>Put a little time into augmenting the bottom battery locater with some structure.
Pic#2>>>Finally completed the battery compartment lower locator. The padding is installed on the underside (can't see) and all has been coated with final gray. Notice the carpet inserts that the batteries will sit on. Purdy yet functional.
Sounds Good! thanks for the tips... gonna be awhile before I get to put mine in but glad to hear all is well w/yours.
CookieBoy.
     The most important thing was the molding job, and I give it a 10. The carpet sports every little detail of the flooring. They also left plenty to trim off, not that much needs trimmed. As I put in my own padding I had to remove the padding they put on. But I ordered it without any, any way,so I don't know why it was there. Also, the front padding was not put into the mold straight when pressed with the adheisive so it was kinda overlapped and crooked. That corner on passenger front side front had to come off (anyway) and be readhered if I were to use it. I would not take it out of the box and attempt to put it right in. Take it out about a week earlier and work out the wrinkles and check your padding to be sure it's properly in place.
Looks Great! So what do you think of the carpet now... mine is still in the box.
Pic#1>>>Carpet time...Put in.
Pic#2>>>Priliminary fit up.
Pic#1>>>Fabricated the battery base locater for the battery compartment. Using padding to fill in between the tire well base corregations then a 1/4"peice of masonite for the batts to sit on which is adhered to a 1" peice of polytyrene insulation cut out for the batts to fit into. Also this combination has been cut to the same radius graduation from vertical to horizontal at the bottom of the tire well.
Pic#2>>>Covering the front face plate for the storage pod. Also, installed the protective mesh for the speakers. Special note...Am using 4 magnets to keep the lid closed. They are located evenly spaced and inserted in notches cut into the plywood. They are fastened with black RTV and then covered with the carpet.
Pic#1>>>Cleaned,Degreased,Rust Coated,Painted and lubed. These seat rails are ready to go.
Pic#2>>>After a painstaking masking session the dashboard is finally painted>>>Ford gray.
Pic#1>>>>Wow, The carpet arrived today. It took less then a week. I got the Medium Grey.......
Pic#2>>>>Pictured at the top is a hind veiw of the vertical part of the boxing that will occupy the back seat area. The holes are cutouts for the speakers. Pictured at the bottom is the duel battery holddown system taylored to specifially hold 7.250" high batterys in the spare tire compartment as this seems to be the lowest commonly sized bats that can be found. Notice that the back section of the car has undergone coating to prevent rust and vapor penetration.
pic#1>>>>Beginning the rough installation of the back seat storage pod...
Pic#2>>>>All the sizing is done and the cover cut to shape...3 hours of Pinto bliss.
                 Notice.....the Canadian styling.
Pic#1>>>Well here goes the carpet padding.
pic#2>>>4 Hours later and allot of good excercise. Bingo Done. Layed like a decal.
gearhead440
High Horse,
Your ingenuity and attention to detail continue to be an inspiration to me :yinyan:!
After removing the old padding chunks,adhiesive and drying it out, I coat the floor with a Rust arrester called Extend. The left side is done and dry, the right side is freshly applied.
After the Extend is thoughly dry I replace the factory seam sealer with new. In this case I am using a regular 35 year Acrylic/Latex general purpose caulk called Alex Plus and made by Dapp. I am using White as so it is easy to see where I have done.
Special Note > While slopping this stuff about the floor I felt it would not hurt to fill the floor corrigations as I felt it would add a measure of resonance and sound deadening qualities that certainly would compliment rigid motor mounts.
skrach
Got a chance to work on some insets for my door skins. They are going in that empty space to the outside of the arm rests.......
Decided to go with black armrests...........
Putting a little work into sizing up a set of door skin backings. I'm not going to use those plastic retainers, I am going to screw them up.....
Finished the preliminary work on the sun visors and mounted them (trying to get some of the detailing done because I have parts all over the place) I used the same material that I used for the headliner. I will be searching the local craft shop for some edging to enhance the liniar detailing and so I can find them because they seem to blend in really well.
Finally getting some paint in there......Gonna try the shiney thing......Look out 78Pinto here comes Shiney_Horse.
Dashboard here I come.........A pic of where I had installed rear speakers (5 by 7) when I had a back seat. This location will likely be changed considering I am going with a no backseat configuration.
The seats are out and the old carpet was so fragile that a box knife was almost not needed. The carpet padding that I used held up well but I am still removing it to see how the anti-rust coating held up. It held up well. So, armed with my scraper, removal of the carpet padding continues..........
Well, I'm pulling the panels out and have removed the rear glass and just generally cleaning things up. I have decided,based on a suggestion by Pintony to go with a one peice tinted Lexan to cover the two window openings. It will fit within the parimeter of the existing body trim which will stay.I assume it will be lighter as well and I will use the same material for the rear window.
no picture? EDIT:  you got it now!
Pictured here is the maplight installed in its proper location. Also, pictured are Pintony, Original74 and myself taken in front of ThunderPinto with Pintonys new acquisition pictured in the right background.
Here is a picture of the maplight that I have been holding onto for years in anticipation of one day installing. The pictures show it's stock blue color and then painted gray.
Skrach,
    That is a stock dash extension that was used to hide the a/c unit. That is the only part of the a/c configuration that I kept.
skrach
what is that black finish panel on the passenger side under the dash, directly under the glove box? i dont think i have ever seen that before.
78Pinto,
     The Headliner material is actually a thin carpeting that I purchaced at Home Depo and comes in about 6 general colors. It is called Perfection carpet. It is very thin ( like 3/16ths or less of an inch). I am going to use the same stuff for other parts of the interior as well like the door skins and maybe the seats. The assembly technique I employed with adhesive,backing,stringer attatchment is my own brew. I may need to make some adjustments. These adjustments will allow me to gain a finished measurement of of the headliner template and proof that my brew will hold up. I would be happy to pass this recipe on to others if it's preformance is verified. Anybody interested should let me know they are and as soon as the results are in I can begin to pass the recipe on.
