FLOOR PANS
Date: 06/12/2020 07:24 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 04/20/2017 08:56 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 08/01/2023 06:53 pm
Oddsnends
Date: 12/20/2016 10:52 am
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 04/28/2018 04:12 pm
  • Online today: 1,972
  • Guests: 961
  • Total: 961
ThunderPinto gets an Interior.
Started by High_Horse, November 19, 2006, 01:12:45 AM
The entire back edge of the dashcap foam closest to the windsheild had curled up so I employed a splint and clamped the cap to it and will apply RTV hopefully returning it to it's original position.
After a successfull seperation it was apperent that the vinyl had shrunk spitting the foam. The foam was in good plyable condition with no disintegration. Good. I do have two cracks to deal with. Oh. Using black RTV I apply a thin preliminary thin coat to the foam (which sinks nicely into the porus foam) to insure containment and shape.
The final hurdle on this interior job is at hand....It is the dashboard cap. I decided to try to recover my existing cap myself. So upon examination it was evident that the vinyl covering was going to let go of the foam fairly easily but in some spots a 1/2 inch wood chisel was used for seperation. The foam is important.
As soon as I remove a bunch of tools from the Interior boom there is another set right back in there. I wired the gauge panel ( not shown yet) and am getting to the wiring. Decided not to change the ignition position so I am cleaning and lubing everything for reinstallation. It occured to me while looking at (what I call) the Control head, that I did lengthen it(could have been longer still)towards the firewall when I built it as to hide things better. But it looks like a fine nondistructive place to put a forward set of speakers. Five inchers would fit easily, 5 by 7's if it was a tad longer. I had my driver seat in to feel it out and I am glad I tried my hand at rolling my own seat upholstry. They match,they breath and they feel real nice to sit in foam wise.
Pics1&2>>>Crossed a major milestaone and sat in it. Hand stitched using 10lb test fishing line. Ha!! The driver seat is roughed.
Pic#1>>>Been plugging away and rough finished the buckets.
Pic#2>>>The buckets shown along with the cut patterns for the seat backs.
Well had to take a break from the Pinto today. My son and I installed a new intake manifold on his 97 Crown Vic P71 P.I. Twas a nice way to spend the day.
        High_Horses
Just a note to say that I am currently working on the bucket seat reupholstery......yes......I am going to try to do this myself, which, I thought I wasn't going to do. I guess I just had to experience it. I ran a test article to see what is what. I will post pictures as soon as I have something to show.
not sure how you would get the paint to stick to the carpet but I like it.
BTW... Looking Good !!
Pic#1>>>I wonder how this would look painted on that cover.??
Pic#2>>>We will see just how permanant those markers really are. The carpet being used for the battery cover is more like a tweed. The surrounding carpet is a cut pile.
Hello High_Horse,
Your ideas are coming together and looking GREAT!!!!!
Pic#1>>>Battery comp. cover down. Special note...Lucked out and found a set of side panels (blue) in excellent condition. Mine were badly sun baked. Yeah!!!
Pic#2>>>Looks even better finished.
Pic#1>>>1640 Cranking amps.
Pic#2>>>Cut out the battery compartment cover. Not painted.
Thanx Pintossssssss,
pintoossssssss
Man now that looks great. one of these days I will be that far. I like the gage set up you built it looks like it was suposed to be there. I am planning to use the mounts on my trans. tunnel to mount a Alpine flip up screen unit and use the original radio hole for the gages. Well at least that is the plan for now anyway. Keep up the great work. Joe
 Thank you FCanon
I'm starting to see the theme....looks good.
Frank
Pic1>>>Installed tach.,water temp.,oil press., two fan switches and vacuum gauge into plate. Note ...That is a Sun tach. that I bought when I was 19...it finally found a place. Decided against the trick tach. mount for now and may just put the key switch back in for now and will play with it when I have more time.
Pic2>>>Cut the carpeting for the rear and storage pod. Painted the rails that hold the rear panels in place(not pictured).
Excellent idea on the tach mount... gives the hole left behind a purpose.
Thanks CookieBoy,
           I am always into thinking of doing things trick....I love trick. Yah. Kind of a combination ignition. Here is a trick thing for you. Now that my ignition key tumbler is removed I was thinking of using the hole for the tach. mount. Anyway, one thing you will see in all my work is "Ease of Maintenance".
Very Nice! High Horse, that will look good filled w/gages and such. Just for "snits and giggles" you should set the ignition up something like this...
1) flip a switch
2) turn a knob
3) push a button
then..
4) pull a knob to start (once started let go of the knob and it sucks back in)
now that would be cool (OK.. maybe a little silly and a bugger to setup) but when people see you start it... it will make em' think...  ;D
Pics1&2>>>Spent the better part of today covering (I'm going to call it a control head) the control head. It is pictured along with the stock insert. Notice it is a little longer to hide wires a better.
QuotePic#1>>>This is a mockup of where I am going to put my guages, Fan switches,Ignition switch arrangement and whatever else might be comming down the pike. I will move the temp. plate back up on the dashboard to the right of the speedo cluster.
Pics1&2>>>From mockup to reality. Masonite/RTV construction with a steel flat face.
Pic#2>>>Had to taper it off. It's just to boxy looking.
Pic#1&2>>>Covered the pod lid with carpeting. The lid uses a third type of fuzzy carpet that is halfway in shade between the floor carpet and headliner and will extend to the back of the car. The inside of the cover uses the same stuff as the pod front plate and headliner etc. This cannot be differentiated by the pictures. I need now to make some type of lid holder prop rod thing.
CrazyHorse,
    I am not going to ruin the intergrity of the ignition cowl on the steering column, I am just going to put in some rubber grommets to close up the holes. The paint i am using for the dash is Dupli-color NEW FORD GRAY #DE1611, Engine Enamal with ceramic. Seemed like hard stuff and it can be scotch brighted and re-sprayed without curdling as iv'e done with the glove box cover. The carpet i am using is exterior grade and althought anything fades in direct sunlight after time I will be making an effort to keep the sun off of it.
        Seat-of-the-pants_Horse
Horse, Lookin SWEET! A few Q?? tho. If you move the Iggy switch, what are your plans for the hole in the column? Also That gloss grey looks mighty spiffy on the dash & such, is it an automotive body paint? (IE: duplicolor or such) I did the interior on my '74 2 years ago & the fabric I used faded out BAD!
Pic#1&2>>>Spent the day working on dashboard stuff. Painting glove box door and ash tray. Also removed the steering column and painted the cowling, lubed the bearings and generally inspected it. I removed the ignition switch and steering lock. I really don't want that switch there anymore, (maybe I don't want to scratch the paint job) so I am going to do something different.
