Automatic Wagon
Date: 06/14/2019 11:22 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
Date: 10/25/2019 04:05 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
free transmissions
Date: 11/28/2019 10:21 am
Date: 01/28/2021 03:49 pm
  • Online today: 1,972
  • Guests: 1008
  • Total: 1008
ThunderPinto gets an Interior.
Started by High_Horse, November 19, 2006, 01:12:45 AM
Wow! I can't wait to see this in person... 6 more days   ;D
thoraxethree
WOW, thats all that i have to say. Can't wait to see it with some color on the outside!!! And the interior is superb as well. Good job!
Got the dash completed and set the plexiglass on the passenger side....nothing like pulling that sticky covering off of a virgin piece of plexy. I better get snappy it looks like CookieBoy has left the building.
Well this is not an interior part but I'm in the mode to get this baby ready for Tulsa and that ment my front spoiler and air dam. I took it off when I did the v8 conversion and although I drove the car for half a year testing it out I always felt like my garage door was open without it. Another thing scratched off the list. Yessssss!!!!!!
thoraxethree
Well I've got my countdown checklist taped to the windshield. And here is a shot of the driver seat in...I have yet to assemble the back of the pass seat but all parts are ready.
                                                        Hurry_Horse
High_Horse, you've done a great job on the interior! You have been keeping yourself busy!  Jeff
looking good !! 20 day and 22 things.. you can do it !!
Finally got the painting done on the passenger door and frame. This allowed me to get that pesky headliner molding in that runs all the way to the back and that cover that hides the spring assembly for the wagon hatch. Today I installed the door skin, armrest and handles. Yessssss!!!! Just 22 things on the list before Tulsa.
I thought it to be important to show the retainers. Stainless steel 10-24 button head phillups against stainless button washers. I drilled the acrylic 0ne size smaller then 3/8s and fit in rubber collars that reduced to 3/16th. I fit o-rings inside the button washers to hold against the acrylic. I thought this would be good to allow for the expansion differential and water sealing. I will use simple vulcanized rubber to seal the acrylic to the body.
Finally got around to begin fitting up the plexiglass panels. Pictured is the cardboard template.
Trimmed up the template according to body lines, contact points and door opening and I guess I lucked out. Shimmed 1/8th inch from the roof gutter and made it precisly past all the window reccess radi. The stiffness of the acrylic was not beyond flexing to get it to fit better then I expected and it is set to form to it's new contour.
Thoraxethree,
      I seriously considered getting a set like that but being from the roll your own generation I had to pass and get to know my seats better. I have gotten interested in the seats and dashes to the point of wanting to experiment with them further to provide Pinto guys (only) with a good seat and dash alternative. I appriciate your response on the other tread and will be getting back with you. Those are nice seats.
thoraxethree
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG1159&N=700+%2D128277+115&autoview=sku[/url]
They fit but with little room for error, i actually had to re-drill the holes two times to get it to fit right. I also had to make a bracket for them. And, if you can help it, don't do it by yourself, it was hell for me.
Thoraxethree,
        The tweed carpeting for all 100,the floor carpet 130,carpet padding 25, spray paint 25,guages fittings and copper tubing 100,chalk and rtv 25, snaps and snap tool for seats 25, padding for seats 100, a 4 by 8 sheet of 1/4 inch masonite for doors,control head and battery compartment cover 15, plexiglass 130, rubber molding and glue 30, plywood 10, screws,hinges and angle 25, misc and gopher gas 60,
Wagon back panels from bobcat 30. That is 730. What kind of new seats did you get?
thoraxethree
So, this is my question, now. How much has all this cost, i am currently doing the interior in mine and have only spent about 500 (i bought brand new seats) and the back part of the carpet. I tried spray canning the inside, and its not bad, but it's not great either, it scratches easily so i may end up redoing all of it with automotive grade paint. and my dash needs to be entirely replaced or a dash cap, either way that will be a bit pricey.
Thanks Tony V,
      Yah! I picked some up in black but have yet to follow though like you say. I also want to add the v8 like I have on my avitar <-----. I picked up the molding today for the plexiglass and am going to try to get the panels installed. That will be the light at the end of the tunnel and I can start hitting the details. I lost a weeks worth of Pinto due to an unexpected bersitis issue...ouch.
tony v
hey high,car is lookin good. duplicolor makes fabric die. you could really freak out with the pony you painted on the rear carpet. wont fade that bad in the long run either. keep hammerin at it, it looks like its all coming together.   tony v
Rubber side down!!
Pictured below is a sheet of smoked gray acrylic 1/4 inch thick plexiglass that I am going to use to fashion cruising wagon panels with. I called the guy and ordered some custom cut molding that I will use to inset this plexiglass with. I went with a smoked gray tint because my car will ultimatly be painted white and it needs to match the 50's test equiptment....I mean interior.
 :accident:
Let my clueless self in. What is your emerging theme? Battleships? "50s electronic test equipment?
Not that any of us ever painted our homemade model rocket launch equipment gray to make it look more NASA, milspec, or official back when we were kids.
The Comfort control turned out better then I expected considering that I processed it without taking it apart. But I better make it snappy if I am going to make the Central Regional PCCA Pinto meet in Tulsa, Oklahoma June 14th through the 17th.
Now that I got the dash cap done and installed, I can get on with it. Today I spent the morning getting the wiring worked out and back together...like making sure everything is plugged in and the light bulbs all work. Also, I am finally hooking up these two mini Johnson control gauges that have been in the car forever and never hooked up. Ha!!! They are 0-30 psi and I am going to use them to read Water Pressure and Fuel Pressure, just a set of unlit quick referance troubleshooters. What the heck.
Finished the speedo cluster....onward and sideways.
Tony V,
  Thanks for the advice. I will look into Dynamat.
Finished the DashCap. I brushed the carpet gently with a hairbrush and took the supervac to it. Sprayed the first coat of clear on it and found that the fibers were collecting spray beads...NO GOOD!! Grabbed the wallpaper joint roller and rolled the beads away but not without lifting some fuzz cause it was tacky. NO GOOD!!! Dipped the roller into some solvent and was able to press the fibers in to stick...Done, first coat.
Second coat proved that if I spray real close like 1 inch there are minimal beads...Hit it with the solvent roller and worked it till dry to the touch but not so tight as to flatten the texture of the carpet.
Third coat.. Finished the can...Rolled gently with solvent roller till set. The seams went together nicely,no hairballs and no fuzzy apperance...Whew.
tony v
if you are looking for sound deadner, try using DYNAMAT. when i did my 79 4x4 i used it on the doors, floor, and behind the bench seat  wall. the shtuff works great and can really take the contours of the floor. In your wagon, the walls under the back glass would be ideal. also the rear fenderwells. the mat is about an 1/8" thick.   tony v.
Rubber side down!!
The completion of this dash covering is at hand. It is just the outside edges that need to set and I can get on with the surface processing. It required the placement of over 330 1 inch squares and a triangle upon occation.
CrazyHorse,
    Thanks for the input. And your points have undergone serious consideration. This carpet is exterior grade but I do plan to cut a cover that will be in place when the dash is not being displayed. To many don't cut a cover till their dash is bad. Also, During a discussion with Pintony, the subject of dirt and dust penetration was explored. After the squares are installed I will be vacuuming and fluffing the carpet to clean and enhance the checkerboard texture. Then I will be coating/sealing it with a clear vinyl spray, just enough to seal it but not as to loose the texture because it important to match the interior. And hopefully it will enhance the cherkerboard effect. The tweed has minimal stretch as I found out when I tried to adhere it to the silicone shell with 3M adhesive. So recovering is not an option without removing the exhisting cover. By the way I like the way you extended your guage hood I wish I saw that before I got this far. I'd rather be doing and engine.
You do some seriously good work Horse! I took a lot of shortcuts doing my dash. Now I'm paying for it with sun fading.
If the tweed has any stretch to it you can still lay it over the cap in one piece. Since you used RTV you can "sew" it down into the contours with your fishing line. I used 3m spray glue on mine, but I also used fleece as the covering material.
That pic is the day I finished it.
CookieBoy,
    Thanks for the input. But I am really trying to stay with the tweed. Covering the dash foam with RTV gasket silicone worked really well and I am sure it will preserve the dashcap integrity for a long time to come but one problem....Nothing sticks to silicone but silicone. LOL. So here is my plan. I am going to cut the tweed into 1 inch squares( keep it mind that the tweed has a grain pattern) and stick them to the dash in a checkerboard fashion using gray silicone RTV as the adheisive. Kinda like a Mosaic. Isn't there anything about this that is easy.
looking good high horse, the person who did mine used a non-reflective/sun resistant vinyl (don't want shiny in the eyes) and a heat gun to help mold it to the dash pad during the gluing and stapling. Don't use vinyl that is real thin or every little bump will show but also don't use to thick as it will be hard to work with and mold.
Finally completed the coating of the dashcap with two thin coats od silicone RTV. Now to cover Hmmmmm?
