2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 03/18/2020 01:30 am
Date: 11/08/2019 10:01 am
Date: 06/24/2020 06:12 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Windshield
Date: 01/15/2022 09:31 pm
Date: 07/17/2018 09:49 pm
  • Online today: 563
  • Guests: 274
  • Total: 274
Help!!!
Started by kevincolin, February 14, 2004, 11:40:32 AM
sounds like your 180 deg off on the timing. You may think the crank is in the correct location but you may be 180 off. make sure the #1 piston is a TDC, remove the plug and with a wire or something long, rotate the crank untill the piston is all the way up, then , mark that location on the crank pully and locator ( the factory stuff may be wrong. Then, time your cam by making sure the 2 ( O^O ) is streight down AND both the intake and ex valves are closed. Then install the distrubitor so #1 plug wire is in the 11:00 position. The hardest thing is making sure that when you install the belt, you take the slack out at the distrubitor not the crank or cam.
kevincolin
Hi everyone, me and my a couple of my friends are putting together a sandrail and we have a pinto 2.0 (71) on a VW tranny...
Weve done just about everything we can think of to try and get it started but it wont go... it will backfire and fire comes out of the pipe but it wont start... we need some help on how to find how to get the timing right... anyone wanna help?
