Oddsnends
Date: 12/20/2016 10:52 am
Drip rail chrome
Date: 01/14/2017 09:18 am
front end parts
Date: 03/30/2018 12:48 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 03/07/2017 07:03 pm
Date: 11/14/2019 04:02 am
Date: 12/31/2017 11:14 pm
Date: 05/13/2021 05:29 pm
Date: 12/15/2018 02:21 am
  • Online today: 535
  • Guests: 518
  • Total: 518
Pintony's 1600 Pinto
Started by Pintony, November 14, 2006, 09:28:01 PM
Pintaro
Looks good to me
                       Pintaro
Pintopower
This color is great. I am painting my 77 with this whole color scheme, complete with cowled hood and scoop.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
osiyo59
Hey Tony,
Not sure if you picked out your Blue yet but I got to put my vote in. I am going with a mid 90's Ford blue on my 73. Lapis Blue Metallic Paint code # 4506 in PPG DBU. Ill Email A pic to you of the engine bay after I painted it...Rob
Hey Tony V,
Thank you for your response to my 1.6 exhaust ?
tony v
hey there pintony, i ran 2 1/4 with a 4x9 turbo muffler in the far rear. its pretty quiet. its on a 2.3 w/heddman header. if you want it a little more silent, use a chrysler resonator where the cat would be. that should get her pretty darn quiet. and like they said, if ya wanna wrap it and that will 4 sher help too.   tony v
Quote from: Pintony on December 09, 2006, 01:45:47 PM
Hello starliner,
The decel-valve has been blocked.
Curious??? How would that make the engine less noisy???
Rubber side down!!
Pintony,
  What kind of welder are you using? Is it yours? That is some nice work you are doing. Could you please move next door?
Pintony,
    I was going to call ya but this is better yet....Cool!!I bet that baby feels like brand new. That is one dam lucky Pinto.
ADaughen
Tony,
Have you picked a color yet?
Here's the two I have:
21/WA227M (GM - Lazer Blue Metalic Clearcoat)  Found on the 05-06 Chevy Equinox.  IMHO, a nice bright blue.
SN/M7095A (Ford - Sonic Blue Pearlcoat) Found on 04 Mustang GTs.  A little darker, deeper blue than the GM color.
'78 Cruisin' Wagon
cromcru
im not sure if pegasusautoracing.com   has it for the hedders. i know they have exhaust gaskets for the stock motor. also have you thought of grabbing the intake manifold.2 barrel carb and electronic ignition off a late 77 thru 80 model ford fiesta. just a though. i do have PAR catalog. and they list alot of stuff for the 1.6 . also formula ford international makes  parts that are no longer available otherwise. foot note. my first car was 1971 pinto with 1.6 learned alot from it.
if you can't find them already made you might try a sheet of gskt material and cut your own
.....in addition to my previous post, the decel valve , by reducing HC will also reduce CO emissions
Starliner
Before I blocked my de-acceleration valve it would set-up a harmonic noise in the exhaust system between shifts and when slowing down.   I am sure the valve was not adjusted correctly and was in play too long after letting off the gas.  Either way I wanted to take it off anyway.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
Pintony,
      That makes sense to me.
Starliner
Remove & block the de-acceleration valve, it should sound better.   Mine did.
Pintony,
    The car looks good. The sound the car made when you first started it up sounded normal to me. Are you saying that it still sounds that way even after the new exhaust? It would be nice to have that car absolutly silent when it is running. Seeing as how that car was not originally equiped with a catilytic converter and how a small pipe of fairly thick gauge would tend to transmit sonic resenance comparable to a wet string between two dixie cups.......I would probably try to install a resonator somewhere under there. But seeing that I,m the kind of Horse that would not want to restrict flow then I might try an expantion chamber of about 2-2.5 DIA. BY 24"long wrapped tightly with some good quality braided heat tape a couple of layers thick to absorb/transfuse the shock waves.
what diameter pipe did they use on your exhaust system?
What's with the green and purple? Did The Kroffts or Dick Dastardly own the car?
Tony, I think you can still work out the dent in that fender......... :accident:
billnall
Here is another link for paint colors and codes.
http://www.paintscratch.com/
Ford Parts Man
Tony... the 1.6 sure looks a lot differnet than the 2.0 or 2.3 - it's backwards  :)
Looks Good!
You can find about everything at this site. just select a year and make ( Ford ) and you can see all the color charts.
http://www.tcpglobal.com/autocolorlibrary/
How about 1970 Mustang Acapulco Blue # 13357 ?
Quote from: turbopinto72 on November 26, 2006, 04:56:08 PM
Well, tell the Chief hello from the ( Shiny Police  :police: ).
I think this car should be painted Dark Blue............ 8)
GREAT MINDS DO THINK ALIKE!!!!!
Give me an example of color??
Stock 73 Blue metalic or a more recient color???
Another shot of how rust free this car is.
MAN!!!! I reall lucked-out!!!!!
AND!!! NO ZEBART HOLES!!!!!!
Quote from: Pintony on November 26, 2006, 04:52:34 PM
WHAT???
No color sugestions???? ;D
Yes.... I drove right in front of the Chief of POLICE as I came into town.
He probally saw $$$$$$$ signs....
This Pinto has nearly a perfect body. Except for the R.H. fender.
Hartd to believe it is from the Mid-West...
LOOK no rust.
Quote from: turbopinto72 on November 26, 2006, 04:49:04 PM
Tony, quick.Paint the car before your town outlaws to many purple pintos owned by one person............. ;D
WHAT???
Photo of engine as displayed in Ebay add..
Hello Group,
Here is a shot of the engine.
This 1600cc engine starts and runs like a top.
