Date: 04/20/2017 10:10 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 11/14/2019 04:02 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Crane Cam
Date: 02/26/2018 07:50 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
  • Online today: 531
  • Guests: 476
  • Total: 476
Seat removal
Started by FlyerPinto, October 25, 2006, 09:21:19 PM
FlyerPinto
Thanks for the ideas. I bought a set of ramps yesterday so I can get under the car and have a better angle on what I'm working with. I had one bolt break and ended up cutting the head off the other one with a Makita grinder...since most of the floor is gone anyway, and it didn't hurt the rails for the seat I didn't figure it would be much of a loss anyway. I hope I wasn't wrong about that idea. I'll work on the car this weekend and let you all know how I did.
1977 Bobcat HB
1977 Bobcat HB
1978 Pinto Cruising Wagon
Trent
when i took mine out to clean my carpet i ran into the same problem, im in a 1980 ford pinto that sits pretty low, now, i being a rather big guy myself, (about 260) can only fit my shoulder under the car, but it was enough to finger around and find where the bolts were, i took a regular socket wrench with an extender and a deep socket, and put a small peice of scrap pipe about 2 foot long on the end of the socket wrench, the pipe gave me enough leverage with my right hand on the socket holding it on and my left on the elongated wrench that they didn't ose much of a threat, the grease and rust broke free, and i only lost one which i twisted off at the nut, just replaced with with a nut and bolt out of my parts bin.
if all else fails douse it in wd-40 or try a cheap can of carb cleaner, that takes just about everything off.
Quote from: FlyerPinto on October 26, 2006, 06:26:45 AM
The more carpet and what-not I pull out the more I realize this will be a bit of an undertaking to get her solid again.
Been there, keep at it.
FlyerPinto
I haven't tried a breaker bar yet. I've been relying on my incredible he-man strength (Note the seats are still in the car...) thus far, but everything seems pretty frozen up with rust and age. I could try the heat aspect, I hadn't really considered that yet. I am one of those people for whom fire is, shall we say, always an adventure ;) so I have to be careful. I'll give it a go this evening and see what happens. I'll keep you posted on my progress. I should have some photos to post here in the next week or so. The more carpet and what-not I pull out the more I realize this will be a bit of an undertaking to get her solid again.
1977 Bobcat HB
1977 Bobcat HB
You can try heating them up a little and see if they expand and contract enough to break free?  Are you using a breaker bar?
FlyerPinto
I've started trying to remove the seats from the Bobcat and am running into issues getting these things out. When I did this in my own Pinto back in the day, I don't remember it being much of a problem. Right now though these 30 year old bolts are not moving for love or money. Other than hitting them with WD-40 or something similar, my next thought is to drill out the bolts or use a grinder and take the heads off of them. Any other thoughts? I am not able to get under the car at this time as I don't have ramps yet...thanks for any ideas.
1977 Bobcat HB
1977 Bobcat HB
