Date: 10/15/2017 10:03 am
Date: 02/22/2017 01:58 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 04/10/2017 07:30 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 03/27/2017 10:07 pm
  • Online today: 548
  • Guests: 326
  • Total: 326
2.3 Stock timing mark issues
Started by CHEAPRACER, October 15, 2006, 10:05:48 PM
Sorry for the delayed reply.
I found the issue to be more to do with what belt cover/pulley combo you use. The Pinto cover has a pointer and the scale is on the pulley, where the EFI engines have the scale on the cover and a single mark on the pulley. If you use a matched pair you will be fine, otherwise you need to re-mark one or the other.
CHEAPRACER
I'm not sure if it's posted here but you guys switching over to EFI engines and using the old style steel crank pulley may have timing issues. I remembered today after checking my timing that my '74 steel v belt crank pulley is about 20 degrees off on the mark when mating up to a '88 timing belt cover that used the serpentine system. Anyone with the same experience?
