  • Guests: 2457
  • Total: 2457
The Electric Pinto
Started by electrabishi, October 14, 2006, 02:03:46 AM
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
electrabishi
We'll its been a while since I updated on my progress.  I scrapped the '80 after gutting it for some of the hardware I'll use for spares.  This is for map351,  I won't be converting a $100 Pinto anymore  :(   I found a $400 one  ;D  with a straight stock body and an 8" rear to toy around with.  But the Dutchman Motorsports Heavy Duty Street & Strip Ford 9" with Strange N case, 35 spline race axles and Detroit locker will be under it for its first day on the track.
You can see a few photos and more details here http://www.austinev.org/evalbum/1093.  After doing more research on the motors and talking with the long time EV racers I'm upward revising my estimated torque capability to ~1000 ft-lbs.  My primary goal here however is to keep it a street legal/strip machine. ..at least for starters.  I need something that I can drive to shows and not have to trailer.
Also the National Electric Drag Racing Association (www.nedra.com) has a Street Conversion (SC), Pro Street (PS) and Modified Conversion(MC) classes of which the record I'll first be shooting for is in the SC class for 348V+ machines. This by the way is the White Zombie record of 12.151 @ 106.25 mph.  This was the last record John was able to post before the rules changed knocking his Datsun with the Ford 9" rear end out of the "stock" class.  Get out the latest version of  your NHRA rule book and see they have already adopted the NEDRA rules for safety on electric vehicles :
So along with all the regular NHRA rules I' will also have to comply with the NEDRA rules as well.  The tubs and slicks will have to wait until I've exhausted what I can do with the stock car.  I've pretty much concluded though that at the minimum I'll have to connect the front half and rear half frame members. So if anyone has advice on how to proceed with that process I'm all ears.  CalTracs traction bars for now, 4-bar when I'm required to fit a roll bar. :-)
  White Zombie hit 11.466 with a borrowed set of lithium-ion batteries and is now forced into its new 6 point roll cage. No more stock class postings for that Datsun  :-\  http://www.youtube.com/watch?v=1Fmy4tWvr8c  The batteries you wonder???  ...borrowed from Killacycle with its recent 7.824 @168 MPH record setting run at Pomona a couple weeks ago http://www.youtube.com/watch?v=3c8eLH8x_-Y   ...... well back to work - I'm working on the motor mounts tonight.  Next week will be the rear-end so I can get measuremetns for the drive shaft.  My batteries are scheduled to ship December 11th.
Scott Hamilton
This is one of the most intresting threads I have read here...
I was very intrested in the EV story storm and all the crap the auto manufactures folded in mseveral years back..
EV Pinto... WHAT a concept... I went to your site and spent way to much time following links and educating myself..
I 'think' I'm hooked!
map351
First things first. If your claims are correct on the 800/900 ft lbs. TQ you better put some tire under the car! You'll need to back half the car, 4bar,40 spline axles,spool.
Tires and wheels are first get them to fit under the car, measure the wheel mounting flange to flange that's the axle length, build the housing from that point.
Just my view on this, I think you should buy a old super gas car and convert it to a electric car you'll be way ahead of the game! If the car has the potential you claim you will have to deal with all the NHRA SFI safety regulations.. Buy a old proven drag car and have fun..
http://www.racingjunk.com/search?searchString=ford+pinto
This is what you need to start with..  Not a 100.00 dollar pinto!
71 Ford Pinto
Alston 2x3 full tube chassis
narrowed 9" rear end
33 spline axles
488 gear ratio
all aluminum interior
15x12 center line rear wheels
15x 3.5 center line front wheels
$4,200.00 / $1800.00 this week!
phone # 479-938-0168 if no answer please leave a message.
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
electrabishi
Well we have the motors on order from http://www.go-ev.com/  The dealer I bought from however is http://www.evsource.com/ in case anyone was interested.
we ordered a TransWarP9 and a WarP9 and will couple the 1.125" tail shaft of the TWarp9 to the 1.125" shaft of the WarP9 and run them in line. The newly released TransWarP9 comes with a hardened 1.370" splined drive shaft that will direct drive the rear end.
I have a heavywall 9" housing from an '85 Bronco that I've got cleaned up and the spring perches and shock mounts shaved off.  I need to now figure out the dimensions to cut it to fit the Pinto.  Does anyone have manufacturer data on a 1980 Pinto rear end?  My particular donr car has the 6.75" rear.  I've been under it with a tape measure but without yanking the whole axle out I can't be too sure of the numbers.  What I need are the outside of the housing flange to the center of the pinion shaft so I can recreate the setup for the 9" housing.  That driveshaft tunnel looks to be real small.  Any kind of beefed up drive shaft will have some pretty close tolerances so I need to be sure to get the measurements as accurate as possible.  Anyone with experience building an rear axle for a Pinto??
Thanks
Mike,
Anchorage, Ak
electrabishi
I'm in Anchorage, Alaska.  There's decent size IHRA track just north of us and I can't bellieve there is no shop in town that will respline the axles.  But so far no luck.  I'll pick up a racing magazine and see what I can get.   I'll need to buy a differential with a race case anyway when I figure out what gear I need.  Maybe I could pick up race axles from the same place.
Thanks
Mike,
Anchorage, Ak.
where are you located?  other than shipping ( and of course the outright cost of the parts)  what you need should be readily available.  try getting ahold of a National Dragster magazine. The number of 1st rate companies that offer parts/assemblies is enormous.  Your biggest problem will be with whom to do business
electrabishi
So I picked up a 9" axle housing of an '85 Bronco.  Its got the thick housing material and the larger bearing races.  I'm going to have a shop shorten the housing but there'e no one in town that can cut and respline the axles.  What the process to do this.  Would it be better for me to just buy axles built to length?  THe axles that came with the housing are 31 spline, no taper whatsoever.  In fact the axle itself is slightly larger then the splines, for the whole length.  I just don't know how much it'll cost for me to mail them away, have them cut and splined, and shipped back.  Might be better to buy new?
electrabishi
Yeah, Thats Nick Viera who built this while he was in highschool.  He's now going to college and doing an intern with FireFly the industrial battery spinoff from Caterpillar.  His documentation helped me to decide to do my Mitsubishi Pickup conversion.  I kept the 4WD intact as well http://www.austinev.org/evalbum/756
Driving electric is only costing me $30/mo to do my 500 miles a month.  Thats compared to  the $120 I was spending in gasoling for my truck before the conversion.  It was a pretty fun project.  Now I'm going to build up a 12 second dragster out of my 1980 Pinto.  That car will finally get some respect.  Poor thing :-)
QuoteWell, I had to look it up, but about a week ago I was reading about a guy that did the conversion on a Jeep Cherokee, and it even had working 4WD.  His site has a very good buildup with lots of pics.  Here is the link:
http://www.driveev.com/jeepev/home.php
my buddy has it...i'll see if i can get info and pictures from him.
electrabishi
A little Chevette should (could) be pretty efficient.  Is it advertised somewhere?  Do you have a link so I could have a look at what they're trying to sell you?
I just ordered the 348Volt 2000 Amp motor controller today for my Pinto dragster. http://cafeelectric.com/products/zilla/index.html
http://www.evsource.com/tls_controllers.php
Thats 348V X 2000A /746 = 932 HP from the batteries.
Subtract 5% for controller loss, 5% for motor loss and 10% for driveline loss I figure 746HP to the wheels.   I'll be looking at 700 - 800 ft-lbs of torque though. Great for launching a 2500lb car.  Definitely need a well built 9" rearend.
i'm going to wake this thread up....i'm looking at a early 80's chevett with an electric conversion already done.....needs new batteries ect i was thinking about using it as a daily driver....any thoughts?
electrabishi
Quote from: Gaslight on October 14, 2006, 03:59:27 PM
Well a properly built 8" will do the job.  The car just needs to be setup right.  There won't be any tires you can get to fit that will handle that torque.  You need to have it come in at the right time.  Just not all at the same time.
Jake
Knowing that White Zombie (the dautsun 1200) had problems with welds cracking early on even with the professionally built 9" I'm not so sure I'd trust ~900 ft lbs to an 8".  I'd bet a 9" could be built up to handle it fine, however now we're talking serious money.  The thing about series wound DC motors is that they develop maximum torque at 0 (thats zero) RPM, which is right where you want your torque, for launching.  I can't trust that I'd get the car "set up right" as you say, early enough to keep from melting a perfectly good 8" rear-end.  I've checked the yards for used 9" but can't find any of the good 'N' cases, as if that needs to be stated   :( There is a 3.00 locker 9" off a Lincoln in the yard they want $105 for.  I may wind up at least getting it for the housing to start off with.  However the Ford 10.25 is free, but massively heavy.  You gotta love a Pinto to put this much effort into it I suppose.
Mike,
Anchorage, Ak.
Gaslight
Jake
electrabishi
I've actually done this to my Mitsubishi Pickup. http://www.austinev.org/evalbum/756
Its pretty fast, for my daily commuter.  Enough torque to break the tires lose in 2nd gear.  I'm just afraid I'm going to break the tranny or rear end.  Soooo, thus the Pinto project to set up as a racer.  I'll be using two of the motors like in my truck and a 2000 Amp controller.  Looking to see ~900 ft-lbs torque and ~450 H.P. My dilema is trying to find a suitable donor axle to build up.  Would a built 9" hold 900 ft-lbs?  If so it would no doubt be expensive.  I'm thinking that for my first go at a dragster I'm going to use the Sterling 10.25 with 4.11 gears that came off my old F-350.  Its sitting in my back yard for free.  I'd just need to cut it down ~5in on each side.  It'll be heavy, but I won't break it right away.
Mike,
Anchorage, Ak.
Gaslight
Mike,
  I actually had this in mind orginally when I picked up my 74 Wagon.  Do a lot of research before you begin.  In the last couple of years there have been some real cool advances in motor controllers and motor designs.  This is another good site:
http://www.thunderstruck-ev.com/
  With the right amount of research and a solid design you will be real happy.
Jake
electrabishi
Check this out:
http://www.plasmaboyracing.com/videos/PIR%209-28%20run%207.MOV
If John Wayland can turn a Datsun 1200 into a 12 second Electric Dragster what do you think we could do to a Pinto?  I'm gonna find out.  Picked up a 1980 Pinto Sedan a few weeks ago for $100.  I'll probably visiti this list often for some Pinto Know How.
John has other videos posted http://www.plasmaboyracing.com/
Mike,
Anchorage, Ak.
electrabishi at ak dot net
