WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 07/01/2019 12:23 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 02/18/2017 04:41 pm
Date: 09/03/2018 08:58 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Bell housing
Date: 08/23/2017 05:41 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
  • Online today: 175
  • Guests: 159
  • Total: 159
Hello from Manchester!!! in the UK
Started by sierra3dr, August 27, 2006, 02:58:44 AM
71pintok
No I'm the only one with accent(Canadian). One thing I must do is visit there before I die. I'm the heir to the throne ( Dad's brothers all had girls ) . Love to see your car.
Henry
sierra3dr
Quote from: 71pintok on October 26, 2006, 02:32:07 PM
Hey Paul
My parents are from Salford. Do watch the street, if so any scoops?
Henry
Heck no,I can't stand soaps,all it is about arguing.  So where you you born in America?
71pintok
Hey Paul
Henry
sierra3dr
Thanks for the welcome wagonmaster. Sorry I haven't been on the forum recently,I work about 72 hours per week to fund my hobby. I'm concentrating on my XR4i at the moment,because that needs the turbo manifold redesigned due to the original wasn't the best,because I couldn't get the middle spark plug out. This was all done by the previous owner. On top of that,I've got to pay those dredded bills ;D I'm now trying to get the money for a mig welder to put the front wing back on.
Anyway,thanks Bob for the info about the drawthrough setup. It has been mentioned to me that drawthrough can cause fires,but hey,drag racers use drawthrough I think. Anyway,so now,I have decided to go with a blow through because an intercooler can be added.
I intend to use a holley 350. But this project will be happening at a later date.
Bipper
Hello Paul,
At the fordpinto.com home page click on 'your Pintos', go to second page and click on '72 Pangra'. There you will see a picture of a stock Ak Miller turbo installation. It is a draw through system. The carb used in the kit is the standard Pinto carb, a 32-36 progressive 2 barrel. The throttle bores are parallel with the radiator. The fuel inlet is on the radiator side and throttle linkage is on turbo side.
The throttle cable is a very long one from a early Capri.
As far as blow through carb systems I have no experience with them.
Your project sounds intersting.
Bob
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
wagonmaster
Hello and welcome from Anaheim, California, USA!
Brad (turbopinto72) has had a few Pintos with turbos and can probably answer most, if not all your questions, or he will probably know where to steer you to get the information.
Good luck with your project!
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
sierra3dr
Hi gang,
I'm Paul from England (yep,that small island across the pond ;D),and I own a MK2 Ford Sierra 3 door version with a Pinto engine in it. I'm looking at what is necessary to install the blow-through carb type turbo on it. I have the book 'How to modify Ford s.o.h.c engines'.  In the turbo section there's a picture of the Ak Miller turbo setup. I did an engine search for pictures of the Ak Miller set up,but unfortunately there is none. But,it was interesting to read about the Pangra model.
So,how/where does the carb sit? And what carb was used?
I have all the other goodies,i.e 205 block and cossie pistons.
thanks
Paul
